98 Expedition Vibration - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 11-19-2001, 10:58 AM
Box Trotters Box Trotters is offline
Box Trotters is starting off with a positive reputation.
Hi Everyone,
I have a 98 EB 4x4 AWD with 63K miles and I recently had my transmission overhauled by a company that I'd still recommend, but, we're having a problem with a vibration. They thought that it was a torque converter, replaced it, still a vibration. Any suggestions? I've been seeing mufflers, planatery(transmission component), and fuel injectors.
Thanks
Henry ***
Old 11-19-2001, 12:25 PM
rob_nc rob_nc is offline
rob_nc is gaining momentum as a positive member of FTE.
You'll need to provide a bit more detail. Under what conditions does it occur and what kind of vibration?
Old 11-19-2001, 12:29 PM
It's a very suttle vibration that is noticed upon idling and stopped in drive or reverse with brake on. The intensity seems to drop when placed in park or neutral. Not much noticible vibration when driving down the road. It is felt in the front seats and arm rests.
Thanks
Henry
Old 11-20-2001, 07:58 AM
Definitely look into the exhaust system. Pay particular attention to the hanger mount on the back of the trans. These hangers aren't that great to begin with.
Old 11-20-2001, 09:07 AM
Thanks,
I'll look into this. Is this because the bracket is cracked or what? Is there rubber on the bracket?
Old 11-20-2001, 04:47 PM
The bracket has a rubber piece but it isn't much. Try disconnecting the mount from the Y-pipe and seeing if it makes a difference. That's what I found to be the cause on my F150.
Old 11-21-2001, 03:02 PM
buzzard's Avatar
buzzard buzzard is offline
buzzard is starting off with a positive reputation.
Henry, my 2000 4x4 Expedition had/has a very similar vibration. I took it to Ford and they said there was a broken exhaust hanger and supposedly replaced it (I didn't crawl under to see). However, the vibration still exists, maybe I'll get under there this weekend to see what is going on. If you find the source of your vibration, please keep us informed.
Old 12-03-2001, 08:14 PM
Greg1 Greg1 is offline
Greg1 is starting off with a positive reputation.
On my '98 expy my vibration problems went away as soon as I had the tranny's planatory thing balanced, followed by a drivetrain balance.
Old 12-04-2001, 11:55 AM
gblakeney gblakeney is offline
gblakeney is starting off with a positive reputation.
1998 E-150 Subframe Cracked, total loss? discojuggernaut 1968-2013 Full Size Vans 25 09-29-2015 02:38 AM
351 Windsor Connecting Rods D6OE bruno2 Ford Truck Parts for Sale 0 10-21-2013 01:36 AM
vibration at highway speeds j4henry Excursion - King of SUVs 15 07-24-2011 11:12 AM
Looking To Contact Ray Cox Of Saucier Mississippi miottimouse 1973 - 1979 F-100 & Larger F-Series Trucks 1 12-27-2008 07:31 PM
TruboTruck Project 99yellowgt 1987 - 1996 F150 & Larger F-Series Trucks 8 03-22-2007 01:52 AM
Tags
2000, 98, broken, driving, exhaust, expedition, f150, ford, mount, neutral, shakes, stopped, vibrates, vibrating, vibration
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
