high pitch squeal, nat the belts. What could it be?
Old 07-23-2010, 12:39 PM
jonboysranger's Avatar
jonboysranger
jonboysranger is offline
I have a high pitch squeal from inside my 3.0 motor, Thought it was an idler pulley,but when I pulled off the belt, the noise was still there. what could it be. It sounds like its coming from iside the top end??????
Old 07-23-2010, 02:10 PM
Eaglefixer's Avatar
Eaglefixer
Eaglefixer is offline
could be the bearing in the alternator
Old 07-23-2010, 03:19 PM
powersmoked's Avatar
powersmoked
powersmoked is offline
get a 2 foot piece of 5/8 heater hose and put one end to your ear and the other to different parts of the engine........also the iacv has been known to make a squeal
Old 07-23-2010, 07:12 PM
jonboysranger
What is a iacv? And I will diffinatly try the hose trick!
Old 07-23-2010, 07:15 PM
powersmoked
idle air control vlave....it is attached tto the throttle boody and is about 4 inches long by2 inches wide
Old 07-23-2010, 07:27 PM
jonboysranger
will that get louder when I give it gas?
Old 07-23-2010, 07:29 PM
powersmoked
it might........do the hose trick you will locate the noise....
Old 07-24-2010, 07:53 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Welcome to FTE.
The cam sensor, located on the rear passenger side of the engine block on the 3.0L, is known to make a squeek that changes with rpm when it's bearing is going bad, so it belongs on your suspect list.
Old 07-25-2010, 08:55 AM
bankshot's Avatar
bankshot
bankshot is offline
I say cam sensor.
I had a 3.0 destroy the cam sensor gear and caused the oil pump to seize. I'd take a look at the sensor drive gear and make sure it's in good shape.
My opinion of the 3.0 cam sensor design is that it is a major weak link in the motor and terrible engineering design. The motor was intended to have a distributor where the cam sensor is. If a distributor stops (and oil pump too) the engine stops running. This is NOT the case with the cam sensor. If the cam sensor/oil pump stops turning the motor keeps going and commits suicide.
Old 07-27-2010, 06:59 PM
pawpaw's Avatar
pawpaw
pawpaw is offline
If you come to find it's the cam sensor, these folks don't recommed a Dorman.
Alert! Dorman Cam Synchronizer Assembly! - Taurus Car Club of America
Old 07-27-2010, 07:37 PM
LHABY's Avatar
LHABY
LHABY is offline
V-6 ENGINE SQUEAL
My 2000 4.0 ohv engine had the same squeal. If it wasn't for my dealer buds at Tommie Vaughn in Houston I would have lunched the motor. Get it looked at soon.
Harley Hill
11-23-2016 08:19 PM
Pescs334
1999 to 2016 Super Duty
11-05-2015 10:45 PM
chadlyt
08-04-2015 01:16 PM
Jagesage
06-29-2015 11:18 PM
Quick Reply: high pitch squeal, nat the belts. What could it be?
