Air Compressor Options?
An inverter will work but you need to double the watts listed on the nameplate of the motored device you want to run because of the locked rotor amp draw. It takes a whole lot of power to start an air compressor that already has say 85psi in the tank but the pressure switch says it's time to recharge. Makes a really big inverter necessary. The positive benefit to an inverter is you have 120v for other uses too.
on
Clay has the AC pump already to bolt in if you go that rout..its a nice set up....just find the tanks and make up some lines...it fits in where the 2nd alt goes from i been told..
http://www.riffraffdiesel.com/mm5/me...e=F731-AIR-MCR
Riffraff Diesel: ExtremeFlow Belt Drive Compressor
hey guys i've also been looking for over a month now researching on board air sys and cant decide which way is the best route (elec compressor or belt driven), the one that riff raff sells i've seen on another web site and looks great and riff raff is cheaper but the price on the brackets is higher than giraffe's a$$, the one ampslw showed us (vmac) is a very nice set up but looks out of my price range ( can't find pricing ), that compressor is an 70cfm on demand compressor (rotary screw) with engine controling to idle the engine up when there is a demand. i'm going to try post some links to both never tried hope it works, i guess it just comes down to what you really and truly need air for. bracket link. Product Listing - Compressor Mounting Kits vmac link. YouTube - VMAC UNDERHOOD70
I'm looking at installing a Air Compressor on my truck that I can use to pump up my tires and use to provide compressed air for some tools? Main reason for this is so I can inflat my tires to towing levels without having to go home or stop at a tire shop.
Anyone have any thoughts as to what model and type to buy for a 2000 F250 7.3L / crew cab /short bed.
Regards, Madog
Regards, Madog
If you can fab brackets a York a/c compressor is cheap from older Chevy van. Scout a semi salvage yard and get 1 of there air brake tanks. Have line made and it will work its butt off. In the rock crawling dayZ this how friends did it. I have a York I never built in the garage. Or use a nitrogen air tank, size of a large fire extinguisher.
