1997 Powerstroke wiring harness removal
Old 07-23-2010, 10:36 AM
breckman99's Avatar
breckman99
breckman99 is offline
Hello folks,
I'm pulling the original engine out of a 97 F350 and dropping in a 12V that I previously installed in my 90 F250. How deep does the engine harness run on the powerstroke? Are these gauges digital or can I just wire it up to the ford sensors like the 90? Anybody want a cheap (1200) complete running powerstroke engine w/turbo and accesoories/engine harness? Is the computer under the hood just for the engine or will I loose anything in the cab? What dash functions will go nuts when I pull the computer ect?
Old 07-23-2010, 10:42 AM
Talyn's Avatar
Talyn
Talyn is offline
Rubberduck has a wiring harness removal guide.
Its pretty strait forward.
As to the info for your swap, I don't think I've ever seen it here.
People don't swap in 12 valves for 7.3 PSD's very often.
if I had the money. i'd be picking up your motor though.
Old 07-23-2010, 03:04 PM
breckman99's Avatar
breckman99
Yeah, the Powerstroke is a good engine, but I like the 25mpg and more power from the 12v. Any idea if the gauges are run digitally? Or are they just like the old fords with analog signals?
Old 07-23-2010, 08:30 PM
Midwest Dually's Avatar
Midwest Dually
Midwest Dually is offline
Originally Posted by breckman99
Hello folks,
The engine harness runs up to the cab, is connected at the firewall, and held together with a 10mm bolt (its a long one too).
They are still analog. The gauges free sweep when tipped upside down.
The ECU is held in by a frame case that is bolted to the firewall. The ECU itself is actually in the cab, but has to be pulled out through the firewall into the engine compartment. Again its held in by two 10mm nuts, and the wiring connector is plugged in and held together by a 10mm long bolt. You wont lose anything in the cab other then ECU. there are no wires on the backside of the ECU that are run through the cab. You should be able to see it under the brake booster down by the wheel well guard.
Pretty much the truck will go dead when you remove it. Accessories such as PW, PD, Cab light, Glove box light, headlights and tailights should all still work if you have power run to the truck. The gauges themselves wont work.
Dont know if that answers things completely, but hope that helps!
Old 07-23-2010, 09:59 PM
quesey's Avatar
quesey
quesey is offline
location of said motor?
Old 07-26-2010, 06:44 AM
breckman99's Avatar
breckman99
Midwest Dually:
Awesome, so its just like my old truck. I'm sure it will be self explanatory when I start pulling it apart. So I'm guessing they still used the switch/resistor on the oil gauge then? When I found that out I couldn't believe it. Thank you sir.
quesey:
Engine is in Boulder CO.
Here is a video of the engine running:
YouTube - VID 00002 20100725 1320
Brant Bowrifle
20
12-06-2017 10:22 AM
DasCheckers
WTB - Parts & other
11-14-2016 08:07 AM
Ken aka Savage
1999 to 2016 Super Duty
12-29-2015 07:17 AM
1996_powerstroke
10-18-2015 08:58 PM
ironmanisanemic
02-18-2011 12:12 AM
Quick Reply: 1997 Powerstroke wiring harness removal
