DTC P2196 and P0201
Old 07-22-2010, 09:16 PM
chadbostwick's Avatar
chadbostwick
chadbostwick is offline
DTC P2196 and P0201
On my 06 FX4 just got the broken plug out of #4 went to drive it and noticed it running rough. WTF! So I drove it til the MIL came on got P2196 and P0201, and now its smoking to add to the stress. Could the smoking be caused by these codes? What should be my step? OK so I can rule out the injector being bad i switched injectors with another cylinder and got the same code, so something to do with the circuit. Anyone know how to check the wiring at the plug end to see what it should have there?
Old 07-22-2010, 09:23 PM
Coskid's Avatar
Coskid
Coskid is offline
OK the P0201 is the code for the Injector #1 circuit so that could be causing the smoke.
I didn't see anything about a P2196 but a P0196 is for the oil temp sensor and covers the range and performance of it.
I would guess that you have little fuel being added and have burned off some oil.
Old 07-23-2010, 05:32 PM
wildcard30's Avatar
wildcard30
wildcard30 is offline
P2196 - O2 Sensor Signal Biased/Stuck Rich - Bank 1, Sensor 1
<TABLE border=1 cellSpacing=0 cellPadding=3><TBODY><TR><TD style="BORDER-RIGHT: medium none" vAlign=top align=left>Possible Causes: </TD><TD style="BORDER-LEFT: medium none" vAlign=top colSpan=4 align=left>Electrical:
  • Short to VPWR in the harness or HO2S
  • Water in the harness connector
  • Open/shorted HO2S circuit
  • Corrosion or incorrect harness connections
  • Damaged HO2S
  • Damaged powertrain control module (PCM)
Fuel System:
  • Excessive fuel pressure
  • Leaking/contaminated fuel injectors
  • Leaking fuel pressure regulator
  • Low fuel pressure or running out of fuel
  • Vapor recovery system
Induction System:
  • Air leaks after the mass air flow (MAF) sensor
  • Vacuum leaks
  • PCV system
  • Improperly seated engine oil dipstick
EGR System:
  • Leaking gasket
  • Stuck EGR valve
  • Leaking diaphragm or EVR
Base Engine:
  • Oil overfill
  • Camshaft timing
  • Cylinder compression
  • Exhaust leaks before or near the HO2S(s)
</TD></TR></TBODY></TABLE>
wiwillis1980
03-22-2020 07:41 AM
pokateps
2009 - 2014 F150
03-05-2017 08:05 PM
JMW2008
1999 to 2016 Super Duty
02-28-2017 04:01 PM
kcducttaper
20
02-04-2017 06:45 PM
jjward101
2004 - 2008 F150
15
07-16-2014 12:13 AM
Quick Reply: DTC P2196 and P0201
