coolant flush i need help
I posted yesterday about this but i have another question. I know this is probably basic stuff but i just want to make sure i am doing everything right. Like i said in the last post i just bought an 04 F-250 6.0 turbo diesel with 112000 miles on it. it has green coolant in the resivoir and i want to flush it and put the premium gold in it. can anyone give me kind of a step by step on how to do this. I am a little confused because the ford dealership told me i only needed two gallons of the premium gold, the the owners manual says it holds 27.5 quarts obviously water and coolant together. This doesn't make sense to me, am i missing something? Im not sure if i will be able to get all of the green coolant out, if not and it mixes with the gold is that going to cause problems. Thank you for any help i can get.
you will need 3.5 gallons of the gold coolant.
<TABLE style="WIDTH: 655pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=874 x:str><COLGROUP><COL style="WIDTH: 655pt; mso-width-source: userset; mso-width-alt: 30880" width=874><TBODY><TR style="HEIGHT: 14.95pt; mso-height-source: userset" height=20><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: lime; WIDTH: 655pt; HEIGHT: 14.95pt; BORDER-TOP: windowtext 1pt solid; BORDER-RIGHT: windowtext 1pt solid" class=xl24 height=20 width=874>Post #40 in the thread below for a procedure on flushing your coolant:</TD></TR><TR style="HEIGHT: 13.6pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: lime; WIDTH: 655pt; HEIGHT: 13.6pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 1pt solid" class=xl25 height=18 width=874>https://www.ford-trucks.com/forums/690324-coolant-flush-and-refill-procedure.html</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: lime; WIDTH: 655pt; HEIGHT: 12.9pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 1pt solid" class=xl26 height=17 width=874>http://www.thedieselstop.com/forums/f23/6-0l-coolant-nitrite-test-strips-232326/</TD></TR><TR style="HEIGHT: 13.6pt" height=18><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: lime; WIDTH: 655pt; HEIGHT: 13.6pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 1pt solid" class=xl27 height=18 width=874>Procedure on flushing your coolant using VC-9 (Iron Cleaner):</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: lime; WIDTH: 655pt; HEIGHT: 12.9pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 1pt solid" class=xl26 height=17 width=874>https://www.ford-trucks.com/forums/895359-vc-9-instructions.html</TD></TR><TR style="HEIGHT: 12.9pt" height=17><TD style="BORDER-BOTTOM: windowtext 0.5pt solid; BORDER-LEFT: windowtext 1pt solid; BACKGROUND-COLOR: lime; WIDTH: 655pt; HEIGHT: 12.9pt; BORDER-TOP: windowtext; BORDER-RIGHT: windowtext 1pt solid" class=xl26 height=17 width=874>https://www.ford-trucks.com/forums/896281-coolant-flush-home-cost.html</TD></TR></TBODY></TABLE>
Also -
http://wpnet.us/Flush.pdf
Also -
Degaussing is the process of decreasing or eliminating an unwanted magnetic fields. They used this in WWII to "hide" ships from underwater mines that work off magnetic fields
A degas tank is just a reservoir tank for coolant system.
Its just a case of names that sound similar but two total different jobs. neither are related
