Window sticks going up\down after replacing lock actuator
After replacing the lock actuator in the drivers door the window jams up about 6" down. It worked just fine before. It's something to do with the vertical piece of window track that I unbolted to get at the lock assembly but as far as I can see and feel, everything is back in place and the track feels like it is straight. (It's clearly not.) The top of the track sits in a stamped sheet metal bracket and it seems like the rubber seal is supposed to lap over that piece of metal. But maybe its supposed to be fully inside the metal? I tried to do that but I got to a point where it didn't want to go in at the top and didn't want to damage it without finding more info.
Does anyone have any photos or a diagram of how its supposed to go back together? Tips? I'm failing to find relevant photos on Google.
I should have mentioned that I did the passenger side a month ago and while the window still goes up and down, it starts to stick at the same place the drivers door stops, so it's probably not a good comparison. Going to see if my friend will let me open up his door though.
I came across that video but it's not much help.
justintino233
12-01-2007 10:29 AM
