fluid amount - Ford Truck Enthusiasts Forums
fluid amount
Old 07-22-2010, 07:54 PM
joewaldner's Avatar
joewaldner joewaldner is offline
joewaldner is starting off with a positive reputation.
fluid amount
how much fluid does your torque converter hold?? and should I put fluid in it before I put it in place? and how much fluid do I need to fill an e4od... ??
Old 07-22-2010, 09:59 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
The torque converter holds about 8 quarts. You don't need to fill it before install in the trans. The trans will fill it as soon as the engine is started.
An E4OD takes about 18 quarts.
Old 07-22-2010, 10:05 PM
joewaldner's Avatar
alright thanks
manual transmission fluid change 1972fordhighboy2 1967 - 1972 F-100 & Larger F-Series Trucks 13 04-14-2016 07:39 PM
Help Pamela Michelle 1999 - 2003 7.3L Power Stroke Diesel 2 07-10-2015 03:01 PM
How much fluid do I need to completely flush my brake lines? 02GrayPowerStroke 6.0L Power Stroke Diesel 11 04-21-2010 10:23 AM
Brake bleeding ? Nice Work Truck 6.0L Power Stroke Diesel 16 10-25-2009 11:44 PM
Transmission Fluid Capacity cworley250sd 1987 - 1996 F150 & Larger F-Series Trucks 3 09-10-2009 09:47 AM
Tags
1988, 97, amount, amounts, case, diesel, f150, f250, fluid, ford, steering, transfer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
