i found a truck today got trans ???
i found a 1990 ford f250 today i will need a bed no problem but my question is
it is a diesel it sounds ok but he said the trans is pumping out trans fluid out of the bottom of the bell housing he thinks it a seal behind the torx converter i no nothing about diesel engines or trans so here is some info on the truck and the trans is a overdrive napa sayed theres 5 different trans for that model
it is a 1990 ford f250 automatic trans 4x4 extended cab
now if the trans is bad what trans does it take so to find one if i can before i buy this truck it is a project truck after all
Received 3,106 Likes
on
relentlessmx
25
07-14-2021 06:46 PM
Rentaro
08-04-2015 05:47 PM
snakedoc
23
03-30-2011 07:24 PM
