1964-1969 Autolite 2V carburetor - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Old 07-22-2010, 06:35 PM
46yblock's Avatar
46yblock 46yblock is offline
46yblock is gaining momentum as a positive member of FTE.
Wanted, 64-69 Autolite carb, rebuildable core, either 1.08 or 1.14 venturi (size located inside circle on carburetor side).
Old 07-25-2010, 01:06 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
I have a 1.08, but it's a later one from the late 70s I think. Came off a Jeep, and was remanned about two years ago.
Old 08-21-2010, 09:13 AM
1984 F-150's Avatar
1984 F-150 1984 F-150 is offline
1984 F-150 is starting off with a positive reputation.
i'll check on mine later today when i go out. i have a 68 so maby it will be one.
Old 08-21-2010, 09:27 AM
1984 F-150's Avatar
mine is a 1.08 but the tag says motorcraft D4 . i dont know if its the same or not let me know if it is.
Old 08-24-2010, 09:16 PM
357windsor 357windsor is offline
357windsor is starting off with a positive reputation.
I have one from I think '68. I'll check and get you the specs.
Old 08-24-2010, 09:23 PM
46yblock's Avatar
Tag number if there is a tag. Venturi number located inside circle on side of body. If no tag, there is a number stamped, sometimes lightly, on the same side as the venturi in circle, or sometimes on base (foot) of carb. Thanks Mike
choose carburetor capelo Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 7 03-19-2015 03:20 PM
autolite 2150 interference raven3 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 02-06-2015 09:59 AM
Autolite on eBay AbandonedBronco Ford Inline Six, 200, 250, 4.9L / 300 1 01-22-2015 12:01 PM
Autolite 4100 vs. Motorcraft 4180 Carburetors LARIAT 85 Fuel Injection, Carburetion & Fuel System 4 08-11-2011 07:54 PM
Edelbrock/ Carter AFB vs Autolite 4100 carbs, which is better? ClatonK Fuel Injection, Carburetion & Fuel System 4 03-03-2007 11:09 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1964, 1969, 1984, 2v, 69, autolite, carb, carburator, carburetor, carburetors, f100, ford, models, parts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
