What a crappy way to start the day!
When you blow a tranny cooler line a C6 will pump itself dry in very short order! What gets me is it was brand new hose, brand new lines and I went all out and got the good fuel injection line clamps. Plenty of hose on the tube too and the clamp was still tight. Argh!!
So I'm driving to work and the line blows open. I pull over, shut it off (thankfully didn't blow the trans!) and start walking the 2 miles home in the rain. Luckily a local landscaper with a nice Ford F550 turbo diesel stopped to give me a ride home. Grab the tools I'd need, a funnel and tranny fluid and put it in the car and drive out. Threw down some old cardboard on the wet road to crawl around on (in good clothes because I was headed to work (IT Dept)). 5 min later I've got the line together and oil in and we're back in business....
But now I have 2 cars and 1 me.
Drive my car home and pull out my bike I had when I was like 5 years old - I'm talking 12" or 14" wheels and hasn't been rode in like 25 years. Air up the tires and start peddling my butt back to the truck. Stuck in 3rd gear, bike is waaaay too small for me, no rear brakes and both wheels bent and wobbly. Plastic seat hurt my ***, knees hitting the handlebars (also bent) and the darn dog following me the whole way and won't go back home.
Finally get to the truck, throw the bike on the back and try to get the dog in the truck - but he wants none of that. So I pick up the wet dog and set him inside. He goes nutso in the cab. I hop in trying to keep him from jumping out and I end up driving home with wet dog ***** on my CB mic, wet dog paws on my lap and dog panting on me dripping slobber on my crotch. Get home, let the dog out, throw the bike back in the shed, change clothes and go head out to work for the 2nd time...
What a day so far!
What a day so far!
Sucks indeed, but that's how life goes... Where did your cooler line blew, and do you have any ideas as to what caused it to let go? It's a fairly low pressure in there... Oh, on a second read, it sounds like the hose slipped off the steel line? Do you have any flares at the end of the steel lines? Always always make flares, never rely on the friction between the rubber and the steel alone to hold the connection - it don't have to be a 45* double-flare either like you do if there was a flare fitting going on there, just widening the end of the line some is enough, when the clamp can't physically go past the flare things tend to stay put - sure you may get a drip eventually as the rubber ages, but the hose still won't fly off.
Tight just to the point where the ears on the clamp start to bend a bit together.
Thinking back we had some good storms and there were a bunch of branches on the road that I drove over.. I bet one of them buggers kicked up and yanked it! That's about my luck! - and the only thing that can explain how the heck it came off!
Better a cooler line than the new radiator though!
Depending on the size of the clamp you can sometimes tighten them to the point where the two ears actually touch tight against each other. But I could see road debris causing you trouble, that's why bumper sits so low and there are a few skid rails under from it to the engine crossmember, but against branches I don't think even those would help me, they are more against deed and people and such... And yah, better cooling lines than radiator, them things are expensive!!!
Actually shouldn't be as bad as one may think, as there's only a few quarts in the pan, and once the pan goes dry the pump moves no fluid and whatever is contained in the TC and the VB for the most part remains there and don't spill out.
Country Sweetie
37
05-04-2006 10:17 PM
1997RangerXLT
15
05-01-2003 07:34 AM
