Getting Code 542 - Fuel Pump Circuit
Old 07-22-2010, 01:14 PM
mdula's Avatar
mdula
mdula is offline
Don't mean to double post, so I apologize, Im new and I posted this question in the classic trucks section here https://www.ford-trucks.com/forums/9...ll-issues.html but I figure this was the proper place to post.
Basically while cruising the truck would very briefly cut out, whithin a 30 trip it would only happen once. My KOEO test gave me a 211 - PIP erratic or missing (which explains the engine cutting out) and a 542 - Fuel pump open, bad ground or always on. Power / Fuel Pump circuit.
Ive replaced the relay, checked the main ground (rear frame of the trucks ground gets 12.6 volts. Checked the fuel roll-over switch, and tapped all the wiring to try to get the engine to cut off.
Any ideas would be helpful,
thanks, mike
Old 07-23-2010, 01:57 PM
mdula's Avatar
mdula
mdula is offline
No-one has experienced this before? Seen this code? got any ideas?
mdula
17
07-26-2010 09:20 PM
96ford250
07-22-2010 06:31 PM
BCHauler
20
03-26-2009 10:53 AM
twotonestepside
1983 - 2012 Ranger & B-Series
02-28-2006 08:40 PM
Fwayz
Aerostar
04-20-2004 04:47 PM
Quick Reply: Getting Code 542 - Fuel Pump Circuit
