Help with replacing clutch in 1995 Ranger - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 07-22-2010, 11:13 AM
Raving.Ranger.007's Avatar
Raving.Ranger.007 Raving.Ranger.007 is offline
Raving.Ranger.007 is starting off with a positive reputation.
Hey Everyone,
I've got a question for you. I don't know who exactly i need to go to and talk about this, just registered today. I've got a 1995 Ford Ranger. It's got a manual tranny to it and the clutch recently went out. I got a new clutch for it which wasn't bad at all, but now my buddy, dad and i are trying to replace it on our own. I know that we need to disconnect the drive shaft, 4x4 shaft, and the the tranny itself to get to the clutch, but we haven't even gotten to the part where we disconnect the drive shaft. One of the bolts on a support bar under the tranny WILL NOT BUDGE. we've tried heating it up and then hitting it with a air ratchet, even tried cutting it with a nut cutter, but nothing is working...i need help, i miss driving my baby around
Old 07-22-2010, 11:50 AM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Raving.Ranger.007 View Post
Hey Everyone,
the best rust penetrator is a 50/50 mix of atf and acetone(very flamable), the next best is liquid wrench.hit it with that....then get a 1/2 breaker bar with a pipe that should do it............can you access the bolt with a sawsall?
make sure you replace the slave cylinder with a good brand.....
Old 07-22-2010, 11:51 AM
Hank85713 Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.
since you already tried to cut, dut thru vertically in an X pattern then use your air chisel to cut the smaller portions off.
Or get a sawzall and have at it.
Old 07-22-2010, 11:57 AM
it sounds like you might have trashed the head of it.fyi next time make sure you have the correct socket and only use a 6 point one and lube it up the day before with a rust penatrtor........try like we suggested and see if you can get a sawsall in there.......i believe the bolt goes into one of those sliding clip nut things like the ones that hold the bed on!
and not to sound like a nag.....but make sure you replace the slave cylinder!!!!!!!!!!
'89 Ranger Clutch Help Crick07 Ranger & B-Series 5 02-06-2014 09:57 AM
1991 Explorer 5spd Jerking Intermittently Alacarteauto Explorer, Sport Trac, Mountaineer & Aviator 7 12-09-2013 05:39 PM
Help! P0734 Code americangirl Ranger & B-Series 4 06-07-2012 09:02 PM
ZF6 Clutch work Blackbeltdually 1999 - 2003 7.3L Power Stroke Diesel 5 07-29-2010 05:15 PM
Rear Drive Shaft Length coolguy1419 1987 - 1996 F150 & Larger F-Series Trucks 6 06-16-2010 05:28 PM
Tags
1995, 2004, 4x4, 95, ac, change, changing, clutch, fixing, ford, needed, ranger, remplaced, replace, tools, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
