4.2 timing chain? - Ford Truck Enthusiasts Forums
4.2 timing chain?
Old 07-22-2010, 06:36 AM
FordCwazyGuy FordCwazyGuy is offline
FordCwazyGuy is starting off with a positive reputation.
4.2 timing chain?
I have a 97 F150 auto 2WD short bed.
I havent messed with it for quite a while since i have a 2000 F250 SD 7.3.
Before i stopped driving it ,it had a terrible miss mostly at low rpm's and was becoming weak at all rpm's
One day while sitting at idle it just quit and would not start back up,sounded like it was hitting and missing a cylinder while trying to start.
I'm goin to start doing some process of eliminations this weekend to find the problem...
How do i check to see if it is the timing chiain off a tooth or off completely?
I'm old school and we used to just pull the distributor cap and see if the cam was in time with the crank by looking at the rotor cap..but i'm clueless on how to do this engine with out tearing into the front of it to actualy SEE the timing chain/gears...
It has 216k on it..engine was swapped with a reman at around 110k when a freind owned it because the old one hydro locked and bent a rod
Old 07-23-2010, 09:09 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
Timing chains usually don't have problems on 4.2s. There is a tensioner to take up any slack. I wonder if clogged EGR ports was causing your miss at low RPMs and a valve spring broke when it died. I would start by checking compression and if any cyls are low then pull that valve cover and inspect the valve springs. Also pressure test the cooling system to rule out bad intake gaskets.
5.4 3v tick/rattle plan of attack Moore558 2004 - 2008 F150 22 11-05-2016 11:25 AM
Engine misses and stumbles J. E. C. 1973 - 1979 F-100 & Larger F-Series Trucks 5 07-30-2016 03:32 PM
just bought 05 F250 but having 5.4L motor issues 66 bronco roadster 1999 to 2016 Super Duty 28 04-21-2016 11:28 PM
Calling all 4.0 sohc gurus!! boots6868 Explorer, Sport Trac, Mountaineer & Aviator 11 04-11-2015 11:11 PM
1966 F100 352 - Timing Chain Fitment Issues B00M3R 1961 - 1966 F-100 & Larger F-Series Trucks 5 04-06-2015 12:32 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
42, 42l, broke, chain, check, diesel, engine, f150, f250, ford, spring, timeing, timing, trucks, valve, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
