Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 02-11-2003, 04:46 PM
otto1 otto1 is offline
Garage is empty, add now
otto1 is starting off with a positive reputation.
Angry help! stuck valve
Im looking at buying a ford truck it runs but they say it has a stuck valve? is this comon for flats?
or is this flat on it last leg
any help with this would be great
Dan
  #2 (permalink)
Old 02-13-2003, 08:30 AM
2speed 2speed is offline
2speed is starting off with a positive reputation.
help! stuck valve
A stuck valve isn't very much. What's the oil pressure like? Do a compression check and get the real story. Sometimes you can just whack the valve down with a screwdriver thru the spark plug hole and free it up. But it could have a broken spring, which is still no biggie.....
  #3 (permalink)
Old 02-13-2003, 06:57 PM
tcw tcw is offline
tcw is starting off with a positive reputation.
help! stuck valve
a stuck valve should be no big deal. i would check it out for yourself. never assume.
  #4 (permalink)
Old 02-19-2003, 09:58 AM
soso soso is offline
soso is starting off with a positive reputation.
help! stuck valve
a stuck valve is not that bad, when I got my flattie it sat out side for better part of a year. it was on it,s side and watter got in the exaust man. I had a lot of stuck valves in it I just took out the spark plugs,lots of tranny oiland a lot of taps with a wooden dowel freed them up.it purrs now.It's a good way to get to know your motor
Tags
2002, 46, davidson, exhaust, f150, fix, flathead, ford, freeing, harley, sticking, stuck, tranny, v8, valve, valveford, valves
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
