H1 Hummer wheels
with as many of you guys who are talkin hummer tires/wheels figured you might be interested. price is pretty good.... i will be up that way soon so i can pick them up for ya.
hard to balance a rim that weights a ton, especially with military tires that arent concerned about balancing. you dont balance tires on military trucks. they dont give a crap. you can reduce that weight by "road matching" your tires.
Who ever ballanced thouse was a retard and had no clue what he was doing some times the machine will tell you put this size here then if you spin it again it will tell you to add to it and if its wanting you to do thatg where you already have a lot of weight its wrong useualy puting the weights it wants added to the ones already there 180 off will do here also it looks like the guy just didn't have big enough weights
any tire larger then a 35 you should ALWAYS take it to a place that does semi tires. they have way better machines that are built to balance the big stuff. thats where i took my 42's too. they roll them on the machine, it lifts the tires to the machine and slip it right on.
ya, some big trucks use em to balance the tires. They just rotate to the spot needing weight and balance out. They also offer a steel ring that mounts behind your wheel that uses lead powder that does the same. Place in fresno called "east bay tire" has it on display there.
or if you go to a place were they mount and balance big rig tires like oreo said and ford_six about the bbs, they should have some stuff called equal which is the same concept but it is even smaller than the bbs alotta truckers around here swear by it
Haha no I didn't mean go to fresno for the lead thing I got confused about what thread I was posting on thers a company out of fresno thats got the HMMWV tire and they are like new.
