2 valve to 3v valve conversion - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 07-22-2010, 12:52 AM
V10Pride V10Pride is offline
V10Pride is starting off with a positive reputation.
what is needed to swap to a 3 valve head?
I already have the 3 valve head, would I need different pistons? anything??
Old 07-22-2010, 08:35 AM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Depends on what all you can or are willing to modify.
Honestly,if you're asking these kinds of questions,this is NOT the swap for you.
JL
Old 07-22-2010, 12:47 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
At the risk of being called a pessimist, it's a LOT of work. Either you need the entire 3-valver's electronics, including ABS/air-bag/PCM/dash-cluster and all the wiring, or you need to fabricate a throttle body setup to allow for a throttle cable, and do something about the variable intake plenum.
We can work on it with you, but it is a LOT of work. It's not just a bolt-on affair.
Old 07-22-2010, 04:55 PM
Krewat, I am ready for the challenge.
Old 07-22-2010, 05:56 PM
Krewat's Avatar
Good. Let's start with the idea of putting a 3-valve set of heads and intake on a 2-valve long-block, and using the original 2-valve PCM. Because without the 2-valve PCM you'd have to use the newer Torqshift tranny, which also requires all the electronics modifications I already mentioned.
You need to fabricate a throttle cable mount to the 3-valver's throttle body, and you need to figure out what to do with the variable plenum intake. Also, there was a guy on here, who later disappeared when he sorta got run off for trying to cook up a way to sell a conversion kit after sifting our collective brains for months while he built everything. He used a vacuum dashpot to modulate the variable plenum - and I'm not sure that's the best idea, but he seemed to think it worked.
That guy found out the cam position sensor throws a code when using the 3-valver cam position sensor with the 2-valver PCM. I THINK it might have had to do with the clearance between the sensor and the magnet on the cam gear, because he tried both the 3-valve sensor and the 2-valve sensor, and it still threw the code.
It ran, but always lit the check-engine light for the cam position sensor. Not sure if it was a "circuit" code, or just "not right" code
You'll also need the exhaust manifolds for the 3-valver.
Old 07-22-2010, 08:11 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
doesnt the 3V pcm require the torqshift trans ???
and is it possible to use the 2V pcm on a 3V headed V10 ???
sounds like a nitemare to me..
Old 07-22-2010, 10:59 PM
Pinky Demon's Avatar
Pinky Demon Pinky Demon is offline
Pinky Demon is gaining momentum as a positive member of FTE.
Just offhand, what are you hoping for out of this modification? More power, what?
Old 07-23-2010, 01:31 PM
Krewat's Avatar
The guy who did it and got run off used the 2V pcm, a cobbled-together throttle body adapter to use the 2-valve throttle body on the 3-valve intake (I think, or maybe just cable setup on the 3-valve throttle body, don't remember) and found that the cam position sensor threw a code.
I was trying to work on that code with him when he got into the "kit" and got disgusted. Never figured that one out, but I suspect the clearance was too high between the cam magnet and the sensor, and the 3-valve PCM was more sensitive so it didn't care. Or, the cam magnet was in a slightly different place and the PCM was smart enough to deal with it. He said it ran good, had more power than the 2-valver. With a custom tune, who knows WHAT it could do. A small amount of machining to the face of the cam sensor bung, and again, who knows if that would have helped.
Going into it fresh, a person would have to compare the clearance between the sensor and the magnet on both the 2-valve and 3-valve, and see if the magnet was in the exact same spot, degree wise.
Interesting project.
If I had to do an engine rebuild on a 2-valve, I'd probably try it
Old 07-23-2010, 11:36 PM
my situation is I am doing a rebuild so I decided to put 3 valve heads. I don't know about engines but I have a friend who will do it for me. A few questions.
I know I need the 3 valve throttle body but what do you mean by throttle cable mount?
and will getting a custom intake manifold get rid of the variable plenum?
Old 07-24-2010, 12:06 AM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
As a Ford dealer tech, I can tell you that your little "project" will NOT be a cheap proposition. To get a PROPERLY working V10 3-valve, you're going to need the PCM, transmission (Torqshift), all associated wiring, as well as the necessary plumbing needed to convert your existing return type fuel system to the returnless style that is used on the 3-valve engine.
Now, HOW MUCH of a challenge are you in for?
Old 07-24-2010, 01:25 AM
I want 3 valve power. I was doing a google search and there wasa thread were they talk about prototyping dohc cobra heads for the 6.8, is this even possible. Anyways on to the real subject here, I want to do it but I don't want to use the transmission I currently have, I have a c4 fully built.
Old 07-24-2010, 08:32 AM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is online now
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
The 3V engine throttle body is electronically controlled, there is no throttle cable. Either you need to mount and wire a pedal assembly from a 3V truck in your vehicle or you need a way to connect the throttle cable to the 3V throttle body.
Yes.
Anything is possible given enough time and money.
Then use a PCM from a manual transmission truck.
Old 07-24-2010, 02:40 PM
Krewat's Avatar
I'm assuming you already checked if you can get a C4 bellhousing to meet up to a Ford modular? (Actually, given the dragracing scene, I'm sure they already exist).
Old 07-25-2010, 12:46 PM
If power is what you are really after, it would be far cheaper and easier to just beef up your engine internals, and turbo or supercharge the thing while adding some other mods along the way. Trying to convert this over is going to be big $$$$$$$.
Old 07-25-2010, 02:44 PM
Pinky you make a good point, I was just thinking of getting a turbo for it but I want to know how much power can the block hold before it cracks. I dislike how people say 400-500 Hp I know it can handle more. I come from the mustang scene where 5.4 V8 make over 1000 Hp, and the v10 is the same with 2 extra cylinders. I am shooting for 800 Horsepower twin turbo. Its going to make crazy torque.
whats everyones take on 800Hp v10?
Are the two valve and 3 valve V10 blocks the same? Fefanatic 1999 to 2016 Super Duty 7 09-13-2016 06:52 PM
2v aussie head valve covers breezesboy 1973 - 1979 F-100 & Larger F-Series Trucks 6 10-30-2014 06:33 PM
3 valve swap F-O-R-D Dude Modular V10 (6.8l) 0 02-15-2014 01:48 PM
Head work... need help from the pros!!!! nstueve Ford Inline Six, 200, 250, 4.9L / 300 68 07-14-2011 02:53 PM
400 heads. Brass/Iron guides, years, rotating valves? nothercrash 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 10 09-25-2010 02:02 PM
Tags
2valve, 3, 46, cam, conversion, converting, ford, heads, modular, pictures, position, putting, sensor, v10, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
