49-50 front end with 56 cab
Hey, y'all! I'm just visiting from the 47 and older forum and found this thread interesting. I'm in the process (have been for a little while now) of converting a 47 PU cab into a COE. But not the way Ford did it. I intend to put a real hood on it instead of the flip up grille, for example. Also, the style kinda carried over from the late 30's except for the jailbar look. I'm in the process of cutting the fenders down to fit back partway under the doors. Then I'll have to build a new firewall, modify the doors, widen the existing PU grille... and the list goes on. My point is, if it's something you want to do, print off some pics of trucks of the period you want to use and cut them up. Then you can tape or glue them together, even if you know diddly about computers.
Where there is a will there is a way. I'm kinda curious what that would look like, too.
Dave
Dave
Hi mytbtruck
Is that the 32-valve 4.6L motor?
I went and had a look at your gallery photos, man your truck looks good. Up until I looked at your truck I thought my mind had been changed to look into the 56 shape, but after looking at your truck I am back to thinking that 48-50 is the nicer one.
The main problem I have is that I don’t live in the USA. Currently I live in Ireland but I am moving back home as soon as my daughter finishes university next year. Home is South Africa and they really do not want people driving left hand drive vehicles there, so I will need to convert it to a RHD. That in its self is not a problem when looking at the 48-56 ranges of pickups, as it would not bet too much trouble to change the steering and pedals.
How much room is there on the right hand side of the motor in your truck? Could the steering shat fit down that side? Is your motor centered in the chassis?
Sorry for all the questions, but after I saw your reply I went to bed and could not get to sleep thinking about all the stuff I wanted to ask you. So here I and at 1am Saturday morning trying to ask questions, and looking for the point to stop while it is still polite. I hope I found it.
Thanks
Ian
<!--EndFragment-->
Thanks
Ian
<!--EndFragment-->
That wiring kit came from (thedetailzone.com) It seems kinda pricey but I feel like it was money well spent because it was made for the transmission and engine with all the sensor connectors just like they were on the car. I have a picture of the terminals and computer under the passenger seat. It workd everything just like the car. Transmission has overdrive switch to manually put it in or out. Has OBDII connector for diagnostics.I am well pleased with it.
Hi mytbtruck
Thanks
Ian
<!--EndFragment-->
Thanks
Ian
<!--EndFragment-->
Looks Great
Big-Sarge
6.7L Power Stroke Diesel
47
01-17-2024 10:32 PM
54F350LNB
47
08-06-2019 12:59 PM
parkland
72
11-08-2008 06:56 PM
