2001 Escape Replace PCV Valve - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 07-21-2010, 12:39 PM
CSFord CSFord is offline
CSFord is starting off with a positive reputation.
Smile 2001 Escape Replace PCV Valve
Tip: I just replaced my PCV Valve. I discovered that a long socket 24mm, would fit nicely on the valve. You turn counterclockwise 1/2 turn and then simple pull.
It also is good for installing the new valve.
Craig
1998 Expedition 4WD Rear Air Bags Will Not Air Up LGS 1997-2006 Expedition & Navigator 2 09-24-2016 08:08 AM
No injector buzz when key is turned on? reptyls 6.0L Power Stroke Diesel 2 01-25-2015 06:35 PM
PCV - technical differences 1986F150six 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 01-17-2013 03:05 PM
PCV Valve Replacement Bucksloopy 2004 - 2008 F150 2 01-07-2010 03:12 PM
PCV Valve wont screw into valve cover HELP! jlabrecquevt Ranger & B-Series 1 12-03-2008 08:31 PM
Tags
01, 2001, 2003, change, company, escape, ford, located, motor, pcp, pcv, replace, replacement, valve, vavle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
