5.4 tune up - Ford Truck Enthusiasts Forums
5.4 tune up
Old 07-21-2010, 09:09 AM
baracade's Avatar
baracade baracade is offline
baracade is starting off with a positive reputation.
5.4 tune up
My work truck is a 2007 F150 w/ 5.4 coming up to 100,000 miles, what should be included in the first tune up? No issues to date! Oil changes @ every 5k miles, fuel filter changes @ 15k and air filter as needed.
Old 07-21-2010, 12:29 PM
Twinsdad98 Twinsdad98 is offline
Twinsdad98 is starting off with a positive reputation.
I would change spark plugs, all your fluids- coolant, trans (at least drop the pan, new screw and top off), serpentine belt. Didn't say if 4x4 or not, but I would change axles and t-case if it was.
Old 07-21-2010, 02:05 PM
Coskid's Avatar
Coskid Coskid is offline
Coskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to beholdCoskid is a splendid one to behold
If you have not done so already the PCV Valve should be replaced and most likely the wires for the plugs.
If it is only a 2wd then you would need to do the rear differential fluid.
Old 07-21-2010, 02:50 PM
bridge's Avatar
bridge bridge is offline
bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.
You need plugs, PCV and the normal service items: oil change, rotate tires, new fuel filter, air filter, etc. Your ATF is good until 150K, however a simple drain and fill will suffice for now if you're concerned about it.
Also...these are coil-on-plug trucks, no spark plug wires...
Old 07-21-2010, 04:37 PM
BirdmanStyll BirdmanStyll is offline
BirdmanStyll is starting off with a positive reputation.
there is no regular pcv valve change on the 5.4L its electronic and cost over 100$, whats ATF fluid, all fluids include brake and power steering
Old 07-21-2010, 04:56 PM
bridge's Avatar
ATF...Automatic Transmission Fluid. According to the service manual the PCV valve should be replaced. However, it wouldn't be the first time the service manual said replace something that doesn't exist or is unserviceable
Old 07-21-2010, 04:57 PM
baracade's Avatar
Doesn't the transmission filter need to be changed?
Old 07-23-2010, 12:27 AM
Djack04F150XL Djack04F150XL is offline
Djack04F150XL is starting off with a positive reputation.
The transmission filter can be changed if you change the fluid. I prefer to change them myself but you do not get all of the fluid out when you drop the pan. Only a flush does that. When you change the plugs you shouldat least change the COP boot/wire. I changed to a set of Accel COP's from Summit when I did mine and used Champion #7989 one piece plugs. The coils were personal preference though. If you are doing them yourself strickly follow the TSB and have a Lisle #65600 tool set on hand. Also the 9/16" spark plug socket neede to get the old plugs out. Let the plugs soak OVERNIGHT!!!! Trust me on this, I broke nearly all of mine at 71,000 miles. Ditto on all of you fluids.
4.2 L Tune Up winklershop 2004 - 2008 F150 2 08-22-2013 05:42 PM
08 F250 5.4 Tune Up? Water_Boy 1999 to 2016 Super Duty 3 02-19-2013 06:47 PM
5.4 questions KoolAidMan888 1999 to 2016 Super Duty 3 02-08-2012 01:17 AM
2002 f150 xlt fx4 ext cab 5.4l , 107000 miles Tune up Advice needed SWAT KHAN 1997 - 2003 F150 3 09-13-2011 05:48 PM
2002 f150, 5.4l , 107000 miles, tune up advice needed plz SWAT KHAN 1997 - 2003 F150 0 09-12-2011 07:05 AM
Tags
05, 150, 2003, 2005, 2006, 2008, 54, engine, f150, f250, ford, gas, manual, service, truck, tune, tuneup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
