Guage Sending unit locations - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-21-2010, 07:14 AM
Frozen001's Avatar
Frozen001 Frozen001 is offline
Frozen001 is starting off with a positive reputation.
OK So I am finally going to install some real guages on my 2008 F250 5.4L. I am going to pick up the 3 guage pod by autometer, and I am thinking of going with the z-series guages. I want to get water temperature, oil pressure, and transmission temperature. I would have like to also gotten a volt meter, but there is not a 4 guage pod.
Anyway, I think I am going to use the ttest port for the transmission temperature. I was gong to put it inline with one of the cooland lines, but would rather not cut the tubing. What about locations for the oil pressure, and water temperature sending units? Any ideas?
Old 07-21-2010, 12:37 PM
rwilimo rwilimo is offline
rwilimo is starting off with a positive reputation.
Take a look at the scangage II, it would do all that and more and no senders to install
Old 07-21-2010, 12:52 PM
just another truck's Avatar
just another truck just another truck is offline
just another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputation
Quote:
I Like the idea behind the scan gage, but remember, it is only telling you what the computer thinks it is seeing, so, bad sensor=bad readings.
I am sorry to the OP, but I have not playes with your motor as of yet, use to be though you could get oil presure at the Oil filter housing. There were also places in the head that you could remove a pipe plug, but I dont know anymore..
Old 07-21-2010, 01:18 PM
Frozen001's Avatar
Reason I want the aftermarket is because I just don't trust the ones on the dash. So Scangage is out. I want secondary info.
Old 07-21-2010, 01:24 PM
Quote:
Keep in mind that although the factory gages are crap (actually more like idiot lights) the oem sensors are top notch. I have the Scangage II and can tell you that the information is very accurate. You of course have to decide for yourself what is right for you, but I am here to say I am very happy with the Scangage
Old 07-21-2010, 01:39 PM
Frozen001's Avatar
Scanguage does not show tranny temp, or oil pressure. Only shows:
Fuel Economy
Fuel Rate
Battery Voltage
Coolant Temperature
Intake Air Temperature
Engine Speed (RPM)
Vehicle speed (MPH and KM/H)
Manifold Pressure
(not available on some vehicles)
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
Old 07-21-2010, 02:20 PM
Fuel Economy
Fuel Rate
Battery Voltage
Coolant Temperature
Engine Speed (RPM)
Manifold Pressure
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
Actually it does do trans temp and many other readings through the extended commands. You can download a chart and enter some codes to enable these extra functions. I absolutely use the trans temp every day, this was one of the main gages I wanted for snowplowing.
Old 07-21-2010, 08:34 PM
This link is from there site: http://www.scangauge.com/support/pdfs/XGAUGE.pdf I think the only problem you would have is oil pressure. On the plus side you could get volts and some other cool things.
Old 07-21-2010, 08:55 PM
Frozen001's Avatar
Thanks for the info and the links. I think I am still going to go with the analog guages. I am a firm believer that they are easier to "read". With a quick glance you can tell what is going on.
Old 07-21-2010, 09:48 PM
1975StroppeBaja's Avatar
1975StroppeBaja 1975StroppeBaja is offline
1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold1975StroppeBaja is a splendid one to behold
I put my trans temp in the test port and it works great. Mine's a 4R100 but I'm sure the testport on the Torqshift would work just as good.
I don't know what would be best for water temp...
If there's no easy way to get to the oil pressure, you could use an "oil filter adapter". I used one made by GlowShift and it works great. Here's a link to the one I bought:
Oil Filter Sender Adapter - 22mm 1.5 Thread
Old 08-13-2010, 12:24 AM
Frozen001's Avatar
There has to be an existing oil pressure switch/sending unit that I can tee into....
Old 08-13-2010, 12:42 AM
brd7666's Avatar
brd7666 brd7666 is offline
brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.
In your first post you mentioned a three guage pod, and you said that there is not a four guage pod. If you are refering to the pillar guage pod, then yes there is a four guage pod. You can buy them on Ebay. There is also a single pod that goes on top of the stearing column, and a three guage cluster that mounts under the little holding compartment just to the right of the stearing column. There is even one that can mount up by the rearview mirror that I think holds four. Good luck.
Old 08-13-2010, 06:34 PM
There is, but accessing it is a little tight.
See an old thread of mine on the subject, specifically, the posts by Krewat. His is a V10 but it should be the same on a 5.4L.
http://www.ford-trucks.com/forums/79...ding-unit.html
Old 08-15-2010, 09:03 AM
Frozen001's Avatar
Found the stock sending unit. No way I am I going to get at that with out getting angry. I am going to go with the adapter. Evey have any problems with it coming loose. I assume it just threads on like an oil filter, so I can see it may come loose is not careful.
Also for the 2008 there is not quad pod they only have them for the 99 to 07.
Old 08-15-2010, 09:48 AM
That was my thoughts on the stock sending unit location as well.
The adapter just slides up on the oil filter threads and the threaded part you see in the middle is a "nut" that tightens down on the original oil filter threads to attach the adapter. This design allows us to install the adapter at whatever angle we need to make sure the sending units don't interfere with anything. As opposed to having fixed threads and twisting it on like a filter -- you'd have to leave it wherever it happens to get tight.
I check it every oil change (three times) and haven't found it loose so far.
1984 f150 300 I6 guages not working. Frmnsal 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 08-05-2016 09:25 AM
[DONE] Custom Guage Install, 5.4 3v, 4R75E (Oil Pressure Guage and Transmission Temp) Matt Howell 2004 - 2008 F150 4 06-30-2014 05:53 PM
WATER TEMP GUAGE BAD? KICKEDBACK Ford Inline Six, 200, 250, 4.9L / 300 3 07-31-2011 01:49 PM
How did you guys mount custom guages? mdr617 Bronco II 3 02-17-2011 11:00 PM
Pillar Guage questions 2001 F250 brd7666 1999 to 2016 Super Duty 16 07-26-2010 12:08 AM
Tags
2001, commands, ford, guages, location, ranger, sending, sending unit, temperature, test, trans, truck, unit, vehicles, water, xgauge
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
