Have to change the rear springs
Hello everyone: I need to know if a 4 leaf spring will work to replace a 5 leaf. The eye leaf on the left side front broke and I checked with Jeff's Bronco Graveyard about their 5 leaf set but they said that it would raise the rear end up to high as it has an 8.5" arc. The GAWR for the rear is 3770 lbs. Jeff's has 4 leaf rated at 1770 lbs. per spring. Will these work? Any info would be greatly appreciated. Thanks.
OFLM
03-09-2015 08:24 AM
joegeds
06-02-2014 12:38 PM
brokenpaw
05-27-2010 08:34 AM
