how many quarts of atf for drain and fill
Old 07-20-2010, 12:34 PM
swirlparanoid's Avatar
swirlparanoid
swirlparanoid is offline
im looking to drop the pan on my truck soon and would like to know how many quarts of atf it will take to fill it back up, what fluid do you think i should use?
Old 07-20-2010, 04:00 PM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
Thumbs up
4 quarts if you have the 4R75E and I use Motorcraft MerconV.Castrol makes good fluid too.
Old 07-20-2010, 04:52 PM
Coskid's Avatar
Coskid
Coskid is offline
It could take a little bit more but that should be about the right amount.
Old 07-20-2010, 05:50 PM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
According to the service manual it's 4.7 liters or 5 quarts.
Old 07-20-2010, 06:03 PM
baitmaster's Avatar
baitmaster
baitmaster is offline
Been thinking about doing mine too. Are these syn trans fluids? Looking for one of those drain plugs that you can install on the pan to get the fluid out before you drop the pan. always used these and have never had a prob with leaking or whatever. Of course you have to drop the pan to install it, but much less mess, and with this plug you will drain some of that fluid out more often. A 40 yr trans mechanic once told me that if people changed their fluid once a yr, he wouldnt have any business.
Old 07-20-2010, 06:47 PM
Coskid's Avatar
Coskid
Coskid is offline
My jeep had a drain plug in it and i loved it was so helpful.
Old 07-20-2010, 07:29 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
I put a drain plug in the pan....napa has the bolt in type.....
Also...its 5 quarts......and I got it at the ford dealership
Old 07-21-2010, 04:06 PM
BlueOvalFitter
Thumbs up
This is my 3rd AOD type transmission.Every time i've dropped the pan all I added was 4 quarts,which put the level just inside the cross hatch mark on the dipstick.
Old 07-21-2010, 09:47 PM
Ryan50hrl's Avatar
Ryan50hrl
4th for me actually......and both my 05 and 07 took 5 quarts at change.....you checked while running and warm right???
Old 07-21-2010, 09:52 PM
Coskid's Avatar
Coskid
Coskid is offline
If you read the Haynes manuals they actually say that if the transmission is dry it could take up to 10 qts but since we don't dry fill transmissions it is usually somewhere between 4-5 quarts will fill it up.
Old 07-21-2010, 10:28 PM
bridge's Avatar
bridge
bridge is offline
Sick 'n Tired
If you were to do a transmission fluid replacement as described in other threads by using the trans cooler lines, you would need upwards of 13.9 quarts. That is the capacity of the trans.
Old 07-22-2010, 04:20 PM
BlueOvalFitter
Yes,after driving about 10 miles.While running,putting the tranny in every gear,on a level ground,I check it,in park. 4 quarts puts it just in the cross hatch area.Now,if I were to add a half quart more it would probably put it at the top of the cross hatch area.But why do that when the dipstick reads"DO NOT ADD IF IN THE CROSS HATCH AREA"?
Old 07-22-2010, 07:54 PM
rodinator1234's Avatar
rodinator1234
rodinator1234 is offline
I just did mine today along with putting in a drain plug and it took 5 quarts. I put in 4 ran it about 15 miles and checked it it was low so I put in another quart. 2005 5.4 xlt supercrew.
Old 07-25-2010, 12:50 PM
baitmaster's Avatar
baitmaster
Drain plug and refill is on my "to do" list. Is there a filter or a screen in there?
Old 07-25-2010, 02:54 PM
BlueOvalFitter
Thumbs up
Yes,a filter.
Quick Reply: how many quarts of atf for drain and fill
