Where is the best place to buy new cab mounts? Ebay? LMC? Dennis Carpenter? Whats best? Want to buy them tomorrow so I can start getting it done. Thanks guys.
I realize money is tight for most of us these days but sometimes it's worth saving up for quality parts and often times less expensive in the long run, some of those cheaper overseas cab mounts are known to collapse in on themselves after only a few years, just something to consider.
Sorry to Hijack but those front cab mounts that are riveted to the frame how does one go about changing those? Are you just grinding and knocking out the rivets then bolting in the new ones? Mine have a little rot around the holes that I was going to make a patch for but this just might be easier. Thanks DJ
How did your cab mounts turn out.For others that will read this,the advice montana gave you from Flash back is spot on,they are rock solid.USA made.Others will trash this ,but I got all bolts and rubbers from LMC and they seam decent.My trucks out of the weather though stored in out building.(barn)
