Howdy all! i have a 92 f250 351 with an E4OD tranny. It is skipping 3rd and going straight to OD. ive checked the fluid and it is right on. im not sure what else to check, The shift solenoid maybe? please help
Well, I'll tell ya what helped to diagnose my transmission troubles; I pulled the codes which indicated there was a problem with my 2nd gear solenoid circuit. One solenoid pack later, problem solved.
Try this link for a tutorial on how to get those codes.
Other than that, get an Equus/Innova #3145 OBD1 reader from Checker/Shucks/O'Reilly/Kragen/Autozone. You get the idea. About $30 street.
The trouble codes will help to diagnose the problem.
Also, is the CEL on or is the OD light in the shifter blinking?
