1995 Ford F-150 5.0 timing issues - Page 2 - Ford Truck Enthusiasts Forums
Old 08-13-2010, 04:27 PM
ta2guy73 ta2guy73 is offline
ta2guy73 is starting off with a positive reputation.
I plan to, but that is not the cause of my problems at this time.
Thanks
Old 08-13-2010, 04:35 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Well you said you had to adjust the distributor two times then it starts , thats timing...
Old 08-14-2010, 11:12 PM
Mudsport96's Avatar
Mudsport96 Mudsport96 is offline
Mudsport96 is starting off with a positive reputation.
How bout the TFI module on the side of the distributor. Had a buddy that had a hot start/running issue. Truck was fine when it was cold but when it warmed up it had similar issues. Replaced it with one we had layin around and it ran fine. Just a shot in the dark
Old 08-14-2010, 11:19 PM
I was thinking about going to the salvage yard and pulling a distributor to swap out. I have noticed that the engine being hot makes a difference with mine. I have to retard the timing to get it to start if the motor is hot and it dies. But when it gets cold from sitting for a few hours I have to speed the timing up a little to get it to run smooth.
Old 08-14-2010, 11:50 PM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
You do NOT have the TFI module on the side of the distributor in a 1995 and heat is no longer much of a problem with your Black ICM (TFI module).
Old 07-30-2014, 03:36 PM
jungles82 jungles82 is offline
jungles82 is starting off with a positive reputation.
I know this an old thread but did anyone figure out what fixed it my 95 is doing the exact same thing
Gas station to avoid near Glenn Springs Lake Greywolf Tennessee Chapter 1 05-07-2014 08:55 AM
2002 F250 Gas V10 No Fuel Pressure Not Starting Please Help! Joel351 1999 to 2016 Super Duty 29 01-04-2012 08:26 PM
Rear fuel tank issue brucers Ford Inline Six, 200, 250, 4.9L / 300 3 08-26-2011 08:03 PM
out of ideas 6.0 crank no start. joe.d 6.0L Power Stroke Diesel 44 08-14-2011 07:56 PM
timing mark off 180 degrees=ping under load? ks_kid 1987 - 1996 F150 & Larger F-Series Trucks 4 01-28-2002 12:54 AM
Tags
1986, 1995, 50, 94, big, degree, f150, f250, ford, runn, set, test, timing, truck, v8s
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
