Degas Overflow Tank Spitting Coolant
It was around that mileage. Although it went on for a while. It started along time ago maybe with 25k when I saw coolant loss. Radiator replaced,then still coolant loss,another radiator,then thermostats,still coolant loss,etc. you know what I mean. Takes a week or two for appointments,etc.
Time wize it must have been 1 1/2 years to get it worked out.
But it has been flawless in that it's always at the low mark when cold and never goes above high mark when hot. I just hope the front cover doesn't give me problems down the line.
make sure you find out exactly what they're doing to it when they do it.
If they do the pump make sure they do the cover or ask to see it at that point because damage occurs from this gas problem.
I believe my tech didn't change the cover because he didn't have one in. But he had ordered a pump before hand in case. Or he might of said it wasn't damaged to bad so we'll leave it on.
Damn that sucks! Will it be covered under warranty? If you need anything I am just down here in Pocatello bud. I make my way to twin occasionally anyways.
Basshunter your symptons sounded like my symptons. I hope my HG's aren't going. My coolant stays inbetween the degas marks and hasn't dropped any that I can see. I did have a hight amount of potassium the last oil change but no sodium so they were not sure if it was coolant.
If it is a problem I hope it shows it's head. before 100K. I don't tow anything too big maybe my Lance but I haven't been using it that much so who knows.
#30
