Degas Overflow Tank Spitting Coolant - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis SPONSORED BY:
Old 07-22-2010, 06:17 AM
capt caper capt caper is offline
capt caper is starting off with a positive reputation.
It was around that mileage. Although it went on for a while. It started along time ago maybe with 25k when I saw coolant loss. Radiator replaced,then still coolant loss,another radiator,then thermostats,still coolant loss,etc. you know what I mean. Takes a week or two for appointments,etc.
Time wize it must have been 1 1/2 years to get it worked out.
But it has been flawless in that it's always at the low mark when cold and never goes above high mark when hot. I just hope the front cover doesn't give me problems down the line.
Old 07-22-2010, 10:45 AM
BASSHUNTER's Avatar
BASSHUNTER BASSHUNTER is offline
BASSHUNTER is starting off with a positive reputation.
Twin Falls.
Old 07-22-2010, 10:52 AM
BASSHUNTER's Avatar
Sounds Like that is what's going on with mine also.After looking at the other truck it all makes sense. The water pump is cavitating and producing alot of heat and steam and steaming the degas bottle and puking out the top.Wow maybe we could make a TSB for Ford.
Old 07-22-2010, 11:12 AM
make sure you find out exactly what they're doing to it when they do it.
If they do the pump make sure they do the cover or ask to see it at that point because damage occurs from this gas problem.
I believe my tech didn't change the cover because he didn't have one in. But he had ordered a pump before hand in case. Or he might of said it wasn't damaged to bad so we'll leave it on.
Old 07-22-2010, 12:17 PM
BASSHUNTER's Avatar
My tech ordered a pump and cover and is going to install updated EGR valve.I think the new EGR valve has different hose routing.
Old 07-22-2010, 12:46 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
new EGR valve does not have the coolant going to it.
Old 07-22-2010, 01:11 PM
BASSHUNTER's Avatar
That should help out with less heat going to the Tank and Steaming things up.
Old 07-22-2010, 07:24 PM
I couldn't get mine to install a new egr.. I guess if it's not broke don't fix it.
Old 07-29-2010, 04:58 PM
BASSHUNTER's Avatar
Just got a call fron dealership service dept.Been in testing for 2 days and they say the HG's are leaking under load. Anybody installed ARP studs in 6.4 to know if those are the best to use.
Old 07-29-2010, 05:39 PM
kane gray's Avatar
kane gray kane gray is offline
kane gray is starting off with a positive reputation.
Quote:
Damn that sucks! Will it be covered under warranty? If you need anything I am just down here in Pocatello bud. I make my way to twin occasionally anyways.
Old 07-29-2010, 06:02 PM
R-T0r21on R-T0r21on is offline
R-T0r21on is starting off with a positive reputation.
ARP's should be good. I put in Elite's studs before ARP's were available. Sorry 'bout the Hg's. I did have a feeling that that was the problem.
Old 07-29-2010, 07:19 PM
BASSHUNTER's Avatar
Covered under the 100000 mile eng warr.Just sucks you have to tear down an engine w 41000 miles.So i thought i would put the good studs in when they do the repair.I am out the cost of the studs but just added protection for the future!
  #28
Old 07-29-2010, 09:27 PM
Basshunter your symptons sounded like my symptons. I hope my HG's aren't going. My coolant stays inbetween the degas marks and hasn't dropped any that I can see. I did have a hight amount of potassium the last oil change but no sodium so they were not sure if it was coolant.
If it is a problem I hope it shows it's head. before 100K. I don't tow anything too big maybe my Lance but I haven't been using it that much so who knows.
  #29
Old 07-29-2010, 09:30 PM
Young Gun Young Gun is offline
Young Gun is gaining momentum as a positive member of FTE.
Do you have any mods?
  #30
Old 07-29-2010, 10:51 PM
senix's Avatar
very few headgaskets have failed on this motor. Any mods?
96 7.3 coolant problems roughridn_sob 1987 - 1996 F150 & Larger F-Series Trucks 2 01-07-2017 03:28 PM
To much coolant? sscarboro 6.0L Power Stroke Diesel 4 06-07-2014 12:29 PM
Cold fill marks on the degas bottle rtaylor537 6.4L Power Stroke Diesel 22 02-16-2013 09:12 AM
Coolant behavior in Degas Bottle is crazy capt caper 6.4L Power Stroke Diesel 97 10-19-2012 01:36 AM
Discolored Coolant j-bar 6.0L Power Stroke Diesel 8 01-10-2012 09:58 AM
Tags
64, bass, coolant, degas, duty, ford, hot, hunter, idaho, overflow, resevoir, spit, spitting, super, tank, taurus, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
