Help with DTC P1690-Wastegate Control Solenoid - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-19-2010, 04:55 PM
beerdude41867's Avatar
beerdude41867 beerdude41867 is offline
beerdude41867 is starting off with a positive reputation.
My truck is throwing a SES light. The DTC associated with it is P1690, which says its a Wastegate Control Solenoid malfunction. I checked all the lines to the solenoid, they're good. I think it's the solenoid itself. Ford wants 318.00 for a new one. Other than a junkyard, is there a less expensive, better alternative?
Old 08-24-2010, 04:16 PM
eetalt eetalt is offline
eetalt is starting off with a positive reputation.
I think they may be trying to sell you the wrong item. It took my parts guy about 1/2 hour to come up with the proper wastegate solenoid part number. At first, he thought I wanted the wastegate acuator assembly which runs hundreds of $.
I got the wastegate solenoid for my '99 PSD for a little over $30 at the dealership. The part number I purchased was F81Z-6C673-AA Solenoid Assembly.
Hope this helps. Good luck.
Old 08-24-2010, 07:48 PM
ya, just after I posted, I bought one for 40.00 at the dealer after I told him what I needed, not him telling me what I needed.
Old 01-05-2013, 05:05 PM
herojeep's Avatar
herojeep herojeep is offline
herojeep is gaining momentum as a positive member of FTE.
I know this is resurrecting an old thread, but did replacing the solenoid fix the error code? I have had the same issue for a while now.
Old 01-07-2013, 08:40 AM
dsquared's Avatar
dsquared dsquared is offline
dsquared is a splendid one to beholddsquared is a splendid one to beholddsquared is a splendid one to beholddsquared is a splendid one to beholddsquared is a splendid one to beholddsquared is a splendid one to behold
I had the same issue ~ 1 year ago...Yes, replacing the solenoid cleared the code!
Old 01-07-2013, 12:29 PM
That was a long time ago. Yea it fixed it. Then six months later I threw a SES code for my injectors. The wiring loom inside the right side valve cover unplugged. Bought the $16 plug retro fix at the stealership, and fixed both sides in a day. This forum is an awesome source of info. Good luck!
Old 01-07-2013, 04:24 PM
howellt39's Avatar
howellt39 howellt39 is offline
howellt39 has a good reputation on FTE.howellt39 has a good reputation on FTE.howellt39 has a good reputation on FTE.
Quote:
Just a note on the Ford injector harness wedges. I had one of mine come unplugged after a little more than a year with the wedge installed. That wedge still allows the locking arm to bend, but makes it harder. I had one side already done with a quarter.
Now both sides have quarters. The quarter, in my humble opinion, is superior because it's presence makes it impossible for the locking arm to bend at all.
If you're under the VC's for any reason, I would recommend doing the 50-cent mod. Also, it costs $15.50 less than the Ford kit.
3psi, 99 f350 with van turbo, ebpv delete LDForget 1999 - 2003 7.3L Power Stroke Diesel 47 01-13-2017 08:40 AM
7.3L Surging & Rough idle problem mrjimbov 1999 - 2003 7.3L Power Stroke Diesel 37 01-22-2016 08:42 PM
P1000 DTC Clearing dsquared 1999 - 2003 7.3L Power Stroke Diesel 5 10-11-2011 06:49 PM
P1690 dtc smokersteve 1999 - 2003 7.3L Power Stroke Diesel 0 03-29-2010 04:06 PM
New Predator/codes toby5181 1999 - 2003 7.3L Power Stroke Diesel 7 08-26-2005 10:52 PM
Tags
2000, 2001, 73, 73l, 99, code, control, diesel, dtc, excursion, explorer, f250, f350, ford, p1690, solenoid, wastegate
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
