Truck Misses at Idel and Acceleration - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-19-2010, 12:38 PM
rammertide07's Avatar
rammertide07 rammertide07 is offline
rammertide07 is starting off with a positive reputation.
Hello all, not sure if my signature is working or adequate enough: 2001 F350 7.3, CC, 4x4, recently changed my AFE intake back to stock, 4" MBRP turbo back straight exhaust, TS chip stock/50/75/100/high idel/no start, glowshift gauges trans/pyro/boost, BD torque converter, 315-75-16 TOYO Open Country.....Within the last month it has had an oil change (with filter), fuel filter changed, cps changed, new intake filter.
I noticed a miss after one day I was driving down the road and flipped me chip (no, no) and the truck cut out for a second. After that the throttle was sluggish and when I got home I noticed it shaking every now and then at idle...like it was a miss but not a bad miss. I've had it scanned for compression, contribution, and injectors buzzed, all checked out good. Other day I was driving it back home from getting the driver side axle shaft replaced and it was missing during accleration, no matter what my chip was set on. (forgot to mention I got the sluggishness out, disconnected the batteries and let everything reset). It does this in gear or in park...drive train has no affect on it. Oil pressure was good when I went to the mechanic shop....oil pressure got up to 2400+psi. Fuel pressure is also good at 60psi. I'm thinkig its the IDM, but I'm also wanting other opinions. I've read another forum where a guy had the same issue and he opened the valve on the filter housing, with the truck running, to check for air in the line. When He did this, the truck smoothed out. Any ideas about what would cause it to act like that?? Thanks in advance for replys
YouTube - 7.3 exhaust
Image hosting, free photo sharing & video sharing at Photobucket
Bryan's Low Oil Pressure Woes 226 straight 6 brain75 1948 - 1956 F1, F100 & Larger F-Series Trucks 31 02-05-2016 07:01 PM
andy catpwr1 Fuel Injection, Carburetion & Fuel System 1 07-21-2012 01:20 AM
need some help 07 f-350 6.0 bgreene7 6.0L Power Stroke Diesel 22 03-25-2012 09:05 PM
Could I really need 8 new injectors? bulla 1999 - 2003 7.3L Power Stroke Diesel 154 08-30-2010 08:37 AM
Low Oil PSI and HPOP Failure dieseldrivr 6.0L Power Stroke Diesel 3 12-09-2009 10:11 PM
Tags
1977, 46, 96, accelerating, acceleration, accelleration, cut, f150, f250, ford, good, idle, misses, outs, shakes, starts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
