Making a crew cab (1948 thru 1952 - Ford Truck Enthusiasts Forums
Old 02-11-2003, 07:50 AM
AmeriKen AmeriKen is offline
AmeriKen is starting off with a positive reputation.
It seems that I keep accumulating these trucks and I'm considering making something unusual to haul my old farm tractors.crawlers, and horse trailer.
I'm inspired by "Irondragon's" stretch cab, and the 1950 F-8 sleeper cab.
How about a crew cab? Does anyone know of this being done for a 1948 thru 1952 cab?
I was looking at my cabs and the cab tapers considerably from the cowl to the back. My first thought was to cut off the back and insert a second cab, but the cowl area is much narrower than the rear of the cab.
We, also, have horses and I have a 4 horse trailer. In warm weather we'll go trail riding at the state parks. The problem with this is that I have a '98 F-250 with regular cab. Thus, all 4 of us will cram into the cab.
I thought it would be cool to have an old hauler crew cab.
Ken McWilliams
Dayton, OH
Old 02-11-2003, 09:39 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Ken,
Are you thinking of something like this?
If you're interested emial me off forum and I'll give you the owner's email address.
Old 02-11-2003, 05:01 PM
irondragon79's Avatar
irondragon79 irondragon79 is offline
irondragon79 is gaining momentum as a positive member of FTE.
Ah, I've created a monster.
Well, obviously I've been doing a bit of research on attacking a truck and making a extended cab. From what I have seen there are many ways of going about it, guess it just depends on the builder.
I think for a full 4 door cab you could use 2 cabs to make one, but as you noticed Ken, a normal cab does taper front to back quite a bit. I think with the "back cab" you would have to somehow split the roof and floor to widen it with wedge shaped pieces of sheetmetal (like they did with the F-8), to blend it into the other cab.
With my 2 door extended cab, I simply used a set of doorskins off some junk doors to make my fillers and the extended portion of the cab goes straight back (the taper stops at the rear of the doors)
I guess by the time my truck is show worthy, I'll be parked in a lot full of extended cabs, eh, so much for originality, but hey, they will all look cool.
Jon
Old 10-20-2010, 12:15 PM
Odee Odee is offline
Odee is starting off with a positive reputation.
Hi Ken, How did your crewcab turn out. I am thinking about doing the same with my '52 F7 Marmon.
Don
Old 10-20-2010, 02:23 PM
bobj49f2's Avatar
For your first post you sure dug up an ancient post.
What condition is you M-H in? Be careful, to some M-H faithful on the board altering a M-H is sacrilegious, hope you donned your asbestos underwear.
Old 10-20-2010, 03:11 PM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Quote:
You can likely thank Google for that.
Old 10-20-2010, 04:33 PM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
Quote:
I think he got you on that one Bob,lol
Old 10-20-2010, 05:46 PM
bobj49f2's Avatar
Hey, it's not necessarily not good to dig up old posts. That's that's why there's a search feature on the site.
Don, I hope you'll stick around. We have Darksiders, stock restorers and daily drivers, we're all welcome. Just be aware of Truckdog, he's our resident wheel and M-H guru. He might not enjoy some one messing with a M-H. He won't bite though, he's actually a pretty nice guy and some one you might want to get to know. He got a well stocked library on wheels and M-Hs.
Old 10-20-2010, 06:09 PM
homade's Avatar
homade homade is offline
homade has a very good reputation on FTE.homade has a very good reputation on FTE.homade has a very good reputation on FTE.
Look at 48fordcoe for info on putting two cabs together, his coe has a 51 F1 cab turned around backwards, both rear cab sections removed then the cowl removed on the back cab and the rear attached and it looks great and it only took him 4 months from start to finished, paint and all, check out his gallary.
Old 10-20-2010, 06:48 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is offline
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
I wondered if you'd aimed that at me! But I don't see anything wrong with making user friendly "improvements" to a M-H. I just think M-Hs need to be preserved. And heck, doing one as a crew cab would be a great idea. And don't you remember all the speculation we had about converting one to a Campbell woodie? And last, mine is not gonna be done purely as M-H did it. I've got 4.11 gears now, a set of 19.5s to go on one of the trucks, and I might go really dark side by putting in softer F-2 springs . They were an option on F-3s after all. Stu
Old 10-20-2010, 06:54 PM
51PanelMan's Avatar
Quote:
Please say it ain't so, Stu!
Old 10-20-2010, 07:06 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Beat me to the punch, lol!
Within a year ago or so, someone came on here wanting to sell a crewcab 4x4 too.
Here it is: http://www.ford-trucks.com/forums/89...n-ford-f1.html not a four door, but the cab is longer than the F8 sleeper, IIRC.
Old 10-20-2010, 07:08 PM
Hope I don't get kicked out of the "stocker" club for opening up about all that . It'd break my heart....yeah, right.
I'll add another real common example of M-Hs getting "improved" upon. Think about all the M-H car woodies that exist today that started life as regular M-H converted cars, sedan deliveries, and half tons. There's probably more today than were originally produced. They have gotten to be so valuable that other honest old M-Hs have been cut up and made into woodie donors. I do think that's a shame. But, looking at it from the other angle, so many old M-H trucks have been beaten to death during their service lives that they may be only good as donor vehicles. Stu
Old 10-20-2010, 07:28 PM
48fordcoe's Avatar
48fordcoe 48fordcoe is offline
48fordcoe has a good reputation on FTE.48fordcoe has a good reputation on FTE.
You have to be a little crazy to make it work
Old 10-20-2010, 09:37 PM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Quote:
That's really neat how you did that. Any more pics with the roof done?
CL $500, 1952 F2.. what do u think ? Cody_1948 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 11-03-2012 06:15 AM
Crew Cab Safety vs. Super Cab chrisF-150bound 2004 - 2008 F150 4 02-04-2012 08:24 AM
1948-1952 Cowl vent AAM 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 12-31-2009 06:40 PM
IS an F-350, crew cab, long box, dually too big ? peachboy 1999 to 2016 Super Duty 34 06-22-2008 10:41 PM
Towing 5th Wheel w/ Lifted F350? VI-Shooter 1999 to 2016 Super Duty 5 10-18-2003 09:52 AM
Tags
1948, 1950, 1952, back, cab, crewcab, extended, f8, ford, king, monster, stretch, stretching, thur, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
