Making a crew cab (1948 thru 1952 - Page 2 - Ford Truck Enthusiasts Forums
Old 10-21-2010, 12:09 AM
Odee Odee is offline
Odee is starting off with a positive reputation.
Thanks for the welcome everyone. I recently bought a F7 M-H and I was thinking about doing something unique to it. I wanted to see if anyone has built a crewcab and that is when I ran across the older posts. If I can figure out how to put a picture on here I will show you what it looks like now. The truck needs an engine (thinking about a 429 with a C6) but everything else is there.
I found some new steel wheels for it, but what I really want are some 22.5 aluminum. Has anybody done this?
I know I got a long ways to go on this truck and the wheels should be one of the last things to worry about, but I am just curious.
Would appreciate any help you guys can offer.
Thanks,
Don
Old 10-21-2010, 12:36 AM
truckdog62563's Avatar
truckdog62563 truckdog62563 is offline
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
You might look at the thread about Chuck's F-7 Coleman to read about his wheels. I'm impressed that you say you've found new steel wheels. Are they 22.5s too? I'm not aware of any aluminum wheels that were made having the F-7/F-8's unique 8 lug x 10" bolt pattern. But then again I've not spent much time looking at what Alcoa made for our trucks. If they existed back in the day, though, finding a set today could be a life's work. But you could have custom wheels made by one of the custom shops like Wheels Now or Century Wheel, but they'd be expensive. Stu
Old 10-21-2010, 12:50 AM
I emailed Alcoa, they don't make any. I called Accuride, If I took 400 sets they might be interested and they turned me on to Wheels Now and that's where I came up with the new steels. They said they had made some 8 lug x 10" for Chuck awhile ago but I didn't ask the size.
Old 10-21-2010, 09:36 AM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Thanks,
Don
Actually Don checking out availability of wheels first is a pretty good idea. If you can't find wheels then your project will come to a dead stop. A truck without wheels is about as useful as a rusty heap rotting into the ground in a field. If you start looking for wheels when you start your project you'll be able to have a jump on the search. If you wait until you have your project done you'll have it sitting there until you find wheels. There are many posts from people with trucks using Widow Maker who have their truck done but don't have any wheels.
Good luck on your truck and hope to see pictures soon.
Old 10-31-2012, 12:14 PM
Abomination's Avatar
Abomination Abomination is offline
Abomination is starting off with a positive reputation.
I love to dig up old threads.
I'm actually really interested in 48fordcoe's truck. So much that I'm about to finish gathering the rest of the parts I need to duplicate it with an F2.
Are there any other pics of it - especially under construction? I'm most interested in how he did the floor on the rear cab, and how he split the rear cab to make the doors straight, and the rear not bow inwards anymore...
Like I said, I LOVE 40fordcoe's build. But is it easier to do it this way, with both cabs facing forward?
http://www.ford-trucks.com/forums/11...-pictures.html
Should I cut the vents off the back doors and make the windows rectangles by splicing two rears window frames together for each rear door?
~Jason
Old 10-31-2012, 06:31 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
IMO, I would not put the cabs back to back....I would also make the rear door/windows square.
I had planned to make my COE a crew cab, it would take 2 extra cabs and 4 extra doors to do it.
Old 10-31-2012, 07:44 PM
48fordcoe's Avatar
48fordcoe 48fordcoe is offline
48fordcoe has a good reputation on FTE.48fordcoe has a good reputation on FTE.
My trucks are low low budget ,I would had to have 3 cab and 6 doors .I just could not afford that so I build what I can afford ,it works for me . And back in the day that's the way after market body builder , ambulance , paddy wagon build then . I probably have as much in my truck when it done as most of you guys have on just buying a old truck that has been sitting for 30 years. The orange truck has about 7000. In it and 40,000 miles on it after I finish it .I like it, I drive it ,I made it for me ,I just can't please every one just myself and my wallet
Old 11-05-2012, 05:25 PM
I do have a question for you, 48fordcoe.
The cabs taper in at the firewall. How did you cut the rear cab so that it no longer did (and the doors were straight)?
I could probably figure it out, but wanted to ask, as you've been there.
~Jason
Quote:
Old 11-05-2012, 05:32 PM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
crazy i dont know about that, but crazy talented you might have to be!
Old 11-05-2012, 06:21 PM
48fordcoe's Avatar
No
~Jason
With the fire wall and windshield cut out I used the bracket on the floor that the rear of the seat bolts to in front now the rear, that brought it to the right width for the back panel. I know that makes no sense ,but it work out
Need ideas for sunvisor sag klachaine 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 12-02-2014 11:42 AM
Crew Cab vs Extended Cab vs Regular Cab Aaycapp Car/truck Buying Advice 1 10-05-2014 01:43 PM
2012 F350 Crew Cab SRW 6.7 engine Mileage K3JOE 1999 to 2016 Super Duty 4 04-02-2013 04:11 AM
Pros and cons srw vs drw! Trying to pick! dougbrown 1999 - 2003 7.3L Power Stroke Diesel 55 06-10-2011 02:11 PM
IS an F-350, crew cab, long box, dually too big ? peachboy 1999 to 2016 Super Duty 34 06-22-2008 09:41 PM
Tags
1948, 1950, 1952, back, cab, crewcab, extended, f8, ford, king, monster, stretch, stretching, thur, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
