Has anyone noticed decrease in gas mileage
In the last few weeks my gas mileage has dropped about 2 mpg.
I have no codes set.
Tires are inflated properly.
Exhaust seems to be flowing good (can't tell if there is any restriction in the exhaust/cats).
No noticable loss of power.
No change in driving conditions or usage of accessories.
Nothing has changed and nothing seems to be wrong with truck yet mileage has dropped.
Beginning to wander if gas formula has changed or something.
Anyone else noticed a difference?
These motors tend to drop quite a bit of gas mileage when used with the 10% ethanol stuff. Make sure your 'regular station' didn't change up gas mixtures on you. An easy way to test, try a different station with known 100% gasoline.
#2-E10 fuel-This crap is terrible for fuel economy, and unfortunately is everywhere now.
JL
thomast, respectfully, I am in suspect of your 17/18 claim let alone 19/20 mpg.
99.9% of these stock trucks never approch that mileage.
Certianly if I run with an eye on my monitor display, I can get the mileage up to the 17 range but that is never an average of overall fuel mileage due to stop and go traffic included, that drops the average down.
The ETH. in the gas will drop your fuel mileage as well as high ambient temps will retard the ignition timing , then add the A/C load on top of that.
The PCM is looking full time at the intake air temperature as one major way is controls ignition timing and fuel injection levels.
The OX sensors look at the extra oxygen produced by conversion from the ETH in the gas and increase the amount of fuel just from that action alone because the sensors are calibrated for gas without additives..
So you have a number of things going on all at the same time.
Good luck.
Good luck.
I have done a lot of mods to this truck to get it there.
Headers, Superchips programmer in Mileage XS mode, K&N filter and intake mods, electric fans with a switch that I can cut them off once moving.
I do get this kind of mileage if I watch for redlights and coast if it is red ahead.
I have also found that if you go ahead and accelerate up to speed fairly quickly it helps too. Not full acceleration but a good 1/2 throttle instead of slowly accelerating for a longer period of time.
I found a station today that had no ethanol (Supposedly). Will see if that helps.
This is a shot in the dark, Thomas, but check for critter invasion under the hood, in the intake tube in the fender wall, in the exhaust, chewed wires. Something could've happened that hasn't thrown a code yet, or may not throw a code at all but hinder it just enuf to throw the mileage off......
Rick_Ford
2004 - 2008 F150
09-01-2016 09:18 PM
94fordiditurbo
11-23-2015 10:13 AM
AbandonedBronco
93
03-21-2014 11:14 PM
