02 F250 7.3 Transmission Question (hard shifting) - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-19-2010, 08:07 AM
Battman76 Battman76 is offline
Battman76 is starting off with a positive reputation.
I'm looking to buy an 02 F250 with a 7.3 turbo diesel. The one I'm looking at has an automatic transmission (I forget the name or number) but a buddy of mine says its a good tranny. I've not drove a diesel or truck with that much get up and go before. My question is however does the transmission on those type\year of trucks shift harder than say your average transmission? (like my explorer or my father in laws 150?) There is no hesitation at all when it shifts but it's quite noticable and I'm just wondering if that's common or expected.
The guy selling it says it's common in that type of truck he's sold 2 or 3 in the past 3 years that have done the same thing) and he even set the truck to 'tow mode' of the variable settings via programming.
Any advice is appreciated. Thanks,
Old 07-19-2010, 09:01 AM
Franko72's Avatar
Franko72 Franko72 is offline
Molon Labe
Franko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud ofFranko72 has much to be proud of
I have owned three super duty's (two 7.3 diesels) and all of them shifted somewhat smooth, like any other vehicle.(completely stock)
Some programmers will make the truck shift harder. (my DP tuner does)
You mentioned he set it to tow mode with a programmer? what type of programmer?
Alot of these transmissions (4R100) get rebuilt/replaced around the 100k-200k mark, and improvments are added I.E. shift kits, valve bodies ect.
They both improve slow shifts.
Its possible that its just the programmer shortening the shifts. Its better for the trans anyhow, keeps the clutches from slipping while shifting.
Good luck with the purchase, and check out the 7.3 diesel forums. You will learn quite a bit about these trucks over there.
Old 07-19-2010, 09:16 AM
Thanks Frank,
I'll find out tonight the make of the programmer and also try to find out the make of the tranny. The original owner did have the truck only setup for a 5th wheel camper. He mentioned he had the tranny turned up to 'erractic' (if thats really a setting) shifting for that reason.
Old 07-19-2010, 07:01 PM
Mark Kovalsky's Avatar
Mark Kovalsky Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
Quote:
It's a Ford 4R100. It was the only automatic you could get in '02 with the diesel.
Old 07-19-2010, 07:14 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
rbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to beholdrbaker6336 is a splendid one to behold
The Hypertec or superchip programmer will firm up the shifts
Old 07-19-2010, 08:28 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
And the Edge programmer is notorious for making the tranny shift hard. Ask him to set the truck back to stock and see how the shift feels. If you're unhappy with less power from removing the tunes, we can suggest MUCH better tunes that won't give you such a rough shift and will offer tons more power.
Old 07-20-2010, 07:33 AM
Thanks Chris. My buddy does have an 'edge' programmer. I'm not so familiar with programming these things. Where can I find info on how to do so? Is it dependent on the make of programmer? Is there a setting that is just 'stock' and then it will all be back to original?
Currently I think my buddy said it's set for 40 extra horse power or something but I'm sure that truck will be enough truck even at stock for what I need.
If it's not hard to do over this post please do recommend a better tune for me, I really like the truck and want to get it running and shifting as good as I can. Unless of course the tune you mention is based upon the type of programmer.
Thanks!
Old 07-20-2010, 09:00 PM
F350-6's Avatar
Drop a little further down the main forum listing and you'll find the 99 - 03 7.3 diesel section. That's the place to learn about these motors. You'll have your buddy drooling over your truck in no time if that's the route you want to go.
A site sponsor here is DP-Tuner. Other favorites are Total Diesel Performance and lately PHP, Beans, Swamps and some others have started creating a following. The difference with those tunes is they are shift on the fly. If you're driving around in something like a +40 tune and need to pass somenoe on the highway, just turn the switch over to +100 and mash the skinny pedal, then drop back down to the +40 if that's where you like to keep it. The boxed tuners can't do that.
There is a way to hook the programmer back up to the truck and program it back to stock settings. The jerky shifts you're feeling has to do with increased line pressure caused by the tune.
Old 07-21-2010, 08:52 AM
I'll take this thread to that forum, thanks all.
Chris, do you know what Line Pr. PSI for the MAIN transsmission line I want to look for (or is recommened?) I'm going to check it with the edge evolution on the 'tow' setting and then also check it when reset to stock to see if there is a differerence.
Old 07-21-2010, 07:39 PM
F350-6's Avatar
No, that's way above my head. I prefer my manual transmissions, but my wife's truck came with an Edge programmer. The added power was only moderate and some of the shifts were way to hard. We put a chip from Tony (Total Diesel Performance) in and it shifts much better, and the truck will run circles around that old Edge stuff.
1997 F-250 7.3 - Automatic. How to check / changa trans fluid Mercniac Clutch, Transmission, Differential, Axle & Transfer Case 0 08-17-2015 02:23 PM
7.3 which TC questions/opinions 20powerstroke02 1999 - 2003 7.3L Power Stroke Diesel 21 05-07-2014 09:02 AM
E4OD without 3rd or OD NM3 1987 - 1996 F150 & Larger F-Series Trucks 4 05-23-2013 10:47 PM
Should I buy Hnep 1999 to 2016 Super Duty 2 09-15-2012 03:12 PM
'93 F250 Transmission/Dash Cluster Problems LSO1123 1987 - 1996 F150 & Larger F-Series Trucks 6 04-23-2011 08:05 PM
Tags
02, 4r100, 73, 97, automatic, diesel, f250, ford, hard, programmers, rebuilt, shifting, shifts, trans, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
