How Many PSI Do You Run Your Regulators At?
Old 07-19-2010, 03:53 PM
JonathanN's Avatar
JonathanN
JonathanN is offline
The title says it all! I just did a regulated return... I had read that Ford runs the 7.3L at 55PSI and IH ran it at 70PSI. Right now, I'm running mine at 70PSI. I was running it at 60PSI, but upped it to 70PSI to see what it'd do. The truck "seems" to like 60PSI better, but I'm almost positive I'm getting more power outta 70PSI. The thing is, it seems that the more power I get, the harder it is for the truck to put the power to the pavement... I'm gonna try a shift kit and see what happens. But back to the subject... what are y'all running your regulators at?
Old 07-19-2010, 04:18 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
65psi.....
Old 07-19-2010, 06:35 PM
CSIPSD's Avatar
CSIPSD
CSIPSD is offline
60psi...
Every injector and motor is different.
Fuel pressure above 50psi will not make more power one way or the other...
Old 07-19-2010, 07:20 PM
JonathanN's Avatar
JonathanN
So what is gained by running more PSI other than possibly a better spray into the cylinders? If that's the case, then I'm not gonna run 70PSI...
Old 07-19-2010, 08:26 PM
Izzy351's Avatar
Izzy351
Izzy351 is offline
The spray is generated by the HPOP pressure. It has nothing to do with the fuel feed to the stix....
Old 07-19-2010, 08:42 PM
Ziggy.'s Avatar
Ziggy.
Ziggy. is offline
60-62psi here, ran it at 70psi for awhile but it seemed to like around 60psi best.
Old 07-19-2010, 09:06 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Tenn01PSD350 is offline
65psi here right now. For the most part what Joe said is correct. Do the math. 3,000psi times 55psi vs 3,000psi times 65 psi. That's only 30,000 psi difference. No real difference right?
Actually I don't think it works exactly that way but I like having PSI to fill my injectors with fuel.
Old 07-19-2010, 09:29 PM
JonathanN's Avatar
JonathanN
That's what I'm thinking... my truck seemed to run better at 60ish PSI. I've got half a mind to put it back down to 60-65PSI. Can anybody think of a reason to run ALOT of pressure? Anybody have any real proof/evidence/experience/data/etc with the different pressures?
Old 07-19-2010, 09:36 PM
Ziggy.'s Avatar
Ziggy.
Ziggy. is offline
I can think of some reason's not too lol
Old 07-19-2010, 09:41 PM
Tenn01PSD350
Me too, pump longevity and reduced likelihood of a leak.
Old 07-19-2010, 09:43 PM
JonathanN's Avatar
JonathanN
Well, if 60PSI is enough to accomplish the same thing as 70PSI, then I see no need to up it anymore than that.
Old 07-19-2010, 09:48 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
you cant compress a liquid.. if you are filling the fuel side of the injector fine at 60 psi, then 70 psi per se isnt going to get "more fuel" into the injector. It will just draw more amperage on the pump=shorter life.
Old 07-19-2010, 09:57 PM
Tenn01PSD350
What he said. Just have what you need to fill the injectors. I choose to go on the higher side. No you cannot compress a liquid, but you can put it under a lot of pressure. When another force acts on that pressurized liquid you get mo pressure. In the end it is the same volume being injected though so get by with the lowest pressure that works.
Old 07-20-2010, 05:49 AM
JonathanN's Avatar
JonathanN
Alright then, I'm gonna put it back down to 60PSI... it seemed to run better at 60PSI anyways.
cory5517
13
11-13-2013 01:57 PM
iggy2
6.2L V8
04-07-2011 07:50 AM
awq134
2009 - 2014 F150
01-24-2011 09:26 AM
Eng1Driver
1999 to 2016 Super Duty
02-19-2008 11:46 AM
jtharvey
76
07-11-2006 10:41 AM
Quick Reply: How Many PSI Do You Run Your Regulators At?
