P0300 code on 2005 F250?? Please Help!! - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-18-2010, 04:38 PM
smokinjoe78 smokinjoe78 is offline
smokinjoe78 is starting off with a positive reputation.
Hey all , newb here. Just brought my truck to advanced auto with the check engine light on. Scanned the truck and came up with random cylinder misfire-code- P0300. I'm the second owner of this truck which currently has 123k on it. Not sure if plugs were ever changed. It starts right up and runs fine, but the light came on & flashed when i had 2 accelerate hard driving the other day. Now its just on. Could it be the plugs, or coils? Any info is greatly appreciated.
ty- sj78
05'-F250 SD
Supercab-FX4
Old 07-18-2010, 04:51 PM
jc8825's Avatar
jc8825 jc8825 is offline
jc8825 is gaining momentum as a positive member of FTE.jc8825 is gaining momentum as a positive member of FTE.
Definitely change the plugs.
Old 07-18-2010, 08:33 PM
xd2200 xd2200 is offline
xd2200 is starting off with a positive reputation.
P0300
If you research this code you will find many possible causes. Changing plugs is always a good idea (use Motorcraft.) If it was a bad coil it would read for example, P0304, meaning coil on #4. Common causes include gas cap not tight/bad, bad gas, dirty fuel injectors, bad EGR or vaccum leak. Also, a number of other possible casues but I would start with these.
P0300 oxt127 6.0L Power Stroke Diesel 4 04-30-2016 05:51 AM
2006 F-150 5.4 P0053 Stevenmed 2004 - 2008 F150 4 03-11-2016 10:28 AM
2007 F350 6.0L Injector Replacement now P0304 and P0300 countryboy00001 1999 to 2016 Super Duty 3 11-16-2010 10:24 AM
codes p0316,p0300,p0302,p0303 soto8704 2004 - 2008 F150 5 09-28-2010 10:21 PM
04 f150 heritage v6 misfire jsims11 1997 - 2003 F150 2 04-17-2009 09:29 PM
Tags
05, 2004, 2005, 250, be, code, engine, explorer, f250, ford, light, p0300, pcm, po300, taurus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
