A/C not quite up to par 260/55 pressure @ 83
The Ex isn't cooling like I think it should. It's cooling, just not great. I put a set of gauges on it. 83 degrees ambient. High pressure was high at 260, low was in the middle at 55.
The book says I either have too much refrigerant in the system or have air in there.
Is the best path ahead to have a full evacuate and recharge done, should I just bleed some out and see what happens, go another route or is something else wrong?
If I've got the gauges and access to a 3cfm pump, is there any reason not to just run this pump to pull the vacuum myself vs taking the Ex into a shop and have them pop it on their recovery machine? In other words, does R134a need to be recovered in order to stay inline with what the feds require/what is good for the environment?
While both pressures are high, I'll bet your clutch fan is weak (or the condenser is dirty) and actually masking an undercharge condition.
Spray the condenser with a concentrated surfactant like Somple Green or Purple Power cleaner. Spray it deep into the fins and let it sit for a few minutes. Blast it out with a water hose and recheck your pressures.
If the pressures are still high (after it dries), mist water over the condenser. If the pressure drops considerably, the clutch fan is weak.
nstueve
23
06-23-2011 07:27 PM
power_speed
23
08-18-2007 09:09 PM
260falcon
12-16-2005 02:27 PM
