05 turbo wont spool - Ford Truck Enthusiasts Forums
05 turbo wont spool
Old 07-18-2010, 02:42 PM
Lovin7.3's Avatar
Lovin7.3 Lovin7.3 is offline
Lovin7.3 is gaining momentum as a positive member of FTE.Lovin7.3 is gaining momentum as a positive member of FTE.
05 turbo wont spool
My Father-in-laws 05 F250 has no boost. I took it for a drive today and it takes along time to build RPM's. the boost gauges doesnt move until you get over 50mph. (which takes 3/4 of a mile to get up to 50mph) and when it does move it only goes to about 2 (two) PSI. I pulled the EGR valve and cleaned it. Nothing changed. Disconnected the cat converter and again, nothing changed. Checked the map sensor line it was clean.
The turbo doesnt whistle or anything. It acts like mine did when i blew a IC boot off. Just runs on all motor. All the boots are tight, none cracked or broke.
Anyone have any ideas before we take it to the stealership?
Old 07-18-2010, 02:52 PM
brickie's Avatar
brickie brickie is offline
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
Plugged EBP tube or dirty MAP would be what I looked at first.
Old 07-18-2010, 02:54 PM
Lovin7.3's Avatar
i checked the map hose it wasnt dirty at all. How can i check the map sensor? ill pull the EBP tube later tonight.
Old 07-18-2010, 02:59 PM
brickie's Avatar
The tube it's self gets plugged with carbon then the sensor can't get a reading.
Old 07-18-2010, 03:05 PM
Lovin7.3's Avatar
yeah I had the EBP tube clog up on my 7.3 a few years ago. How can I check the MAP sensor tho??
Old 07-18-2010, 03:08 PM
brickie's Avatar
Quote:
Not sure,I have never had to.Mine is actually in the bottom of a parts box.
Old 07-18-2010, 03:11 PM
Lovin7.3's Avatar
lol well thanks for the tips. Ill go check the EBP tube shortly. Thanks again.
Old 07-18-2010, 08:12 PM
Lovin7.3's Avatar
I checked the EBP tube and it was not clogged. Any other ideas?
Old 07-18-2010, 09:00 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Turbo vanes could be stuck open...do you have a way to read trouble codes?
Old 07-18-2010, 09:32 PM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Disconnect the EBP sensor and try it.
Do you have a way to look at Baro, MAP and EBP all together at idle? They should all be very close.
MAF/IAT1 sensor connected up?
IAT2 sensor issues can also cause power problems. Is it properly connected?
Are you getting good fuel flow to the upper fuel filter? I assume you do not have a fuel pressure gauge? It is very helpful in troubleshooting and worth getting.
Is the oil level OK - extreme level and/or fuel dilutiuon can be a problem that could create low power.
I would guess that you have made sure that there are no extreme intake or exhaust leaks?
Codes would be nice as Steve suggetsed. Is the VGT solenoid properly connected?
Old 07-18-2010, 09:37 PM
Lovin7.3's Avatar
I have no way of reading codes. He is taking it to the dealership tomorrow to let them read the codes. I'm wanting to get an autoentegrity but i don't have the extra $450.
low boost billbot 6.0L Power Stroke Diesel 25 03-16-2016 04:25 PM
No turbo spool in 4th. No black smoke either. Why no boost? nicksorenson 1994.5 - 1997 7.3L Power Stroke Diesel 8 07-30-2014 07:57 AM
6.0 turbo problem dauntejoel 6.0L Power Stroke Diesel 17 02-08-2014 08:26 AM
ported compressor housing install impressions Justin03PSD 1999 - 2003 7.3L Power Stroke Diesel 23 04-15-2013 09:43 AM
low boost after about a mile or so also speedometer quit busabuggy 6.0L Power Stroke Diesel 23 11-02-2012 12:26 PM
Tags
1996, 350, 60, autoentegrity, f350, ford, low, power, powerstroke, psi, spool, tubo, turbo, untill, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
