No power locks and radio won't turn off. - Ford Truck Enthusiasts Forums
Old 07-18-2010, 01:11 PM
NS F250's Avatar
NS F250 NS F250 is offline
NS F250 is starting off with a positive reputation.
Well, like the title says, my power locks don't do anything, the dome light does not come on, and the radio does not turn off when the door is opened. I have had issues with the door switches in the past (haven't we all?), but this is different. The door ajar light is not on. All fuses are okay, so I'm thinking there must be a short somewhere or I have a bad relay. Any ideas? Thanks.
Old 07-18-2010, 02:39 PM
NS F250's Avatar
I am not sure if this could be related, but every once in a while, the power windows and radio won't work. They both come back on their own after a couple of minutes. I did find a short in the fuel pump wire by the drivers side shock tower a couple of years ago so I double checked that today and found another bare wire in that cluster. I fixed it, but still no go, maybe that was my window/ radio problem? I read in another thread about the GEM and VSM, could one of these be the issue?
Old 07-18-2010, 02:58 PM
tdpower's Avatar
tdpower tdpower is offline
tdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to beholdtdpower is a splendid one to behold
Most of issues that I have read about these was caused by a leaky winshield. I'm not sure if an 02 has a gem or vsm. I know the gem is above the fuse box. Try to see if you are getting any water leaking into the cab.
Old 07-18-2010, 03:16 PM
76'SuperCab's Avatar
76'SuperCab 76'SuperCab is offline
76'SuperCab is starting off with a positive reputation.
Quote:
Sure could be. I recently had to replace my VSM to get my door locks working again. But I was not having nearly as many issues as you are. Have you tried the WD40 in the latch trick already? If so and that didn't work, I think I'd lean toward a VSM first and GEM second. The VSM is a lot cheaper than the GEM (plus, I'm not really even sure if 2002 and on models have a GEM, some other posts seem to indicate it was replaced by the VSM).
Old 07-18-2010, 04:05 PM
Calli's Avatar
Calli Calli is offline
Calli is starting off with a positive reputation.
Check for water/moisture in power window motor? Worked for me
Old 07-18-2010, 04:07 PM
NS F250's Avatar
I checked for evidence of a water leak, but I don't see anything that looks like that is the case. I did spray the latches. In the past when the door switches would stick, the door ajar light would be on, but not this time.
76supercab, I responded to your post in the superduty section, but it looks like you answered my question here. Where is the VSM? Where should I buy it? Part number? Thanks guys.
Old 07-18-2010, 04:11 PM
NS F250's Avatar
Quote:
What were your symptoms? Looks like I need to pull the door panels. We did have like 5 inches of rain last week. Hmm.
Old 07-18-2010, 04:26 PM
tdpower's Avatar
Check this thread for vsm part number. Looks like it is behind the radio somewhere.
http://www.ford-trucks.com/forums/88...umber-vsm.html
Old 07-18-2010, 05:23 PM
NS F250's Avatar
Thanks, after reading that thread and the linked one that's in it, it sure sounds like i have a bad VSM.
Old 07-18-2010, 05:35 PM
nissandoc's Avatar
nissandoc nissandoc is offline
nissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to allnissandoc is a name known to all
When mine does this all I do is pull fuse #19 and it "resets" it of sorts. I' m sure the VSM is going but I'll wait until I have to buy one before I do.
Old 07-18-2010, 07:15 PM
pminne's Avatar
pminne pminne is offline
Rocky Mountain High
pminne is starting off with a positive reputation.
My 2002 does this same thing, probably more so when it is warm outside. After you start it up no windows and no radio, then after 2-3 minutes everything works fine. Are we sure this a VSM about to go bad? This has been happening for years.
Old 07-19-2010, 09:03 AM
NS F250's Avatar
Got me. With my wiring issues, it's hard to say what is causing what. Check your wiring harness by the drivers side shock mount. Mine ran right over it and rubbed through the wire casing of three wires. One was the fuel pump which I found after I replaced the pump. The others I'm not sure what they do. I do think my power lock, door switch issue is the VSM because I took the #19 fuse out as nissandoc suggested and now my locks work, but the door ajar light is on even though I am pretty sure the switches are okay. After reading every thread I could find, it seems 2002's are the only ones that have this problem. I think this was the first year for the VSM and it was a dud, and they were changed for '03.
Old 07-19-2010, 09:20 AM
nissandoc's Avatar
Does the radio cut off when you open the door now?
And you did put the fuse back in didnt you?
Old 07-19-2010, 09:53 AM
NS F250, missed your follow-up yesterday but it looks like you found the answers. The module is at the firewall, just above the transmission hump. I bought my replacement from Parts Guy Ed (Y2KFord. . .). Like the thread that tdpower poseted, I noticed it is a new part number from the original. Hopefully they made some changes that will keep this one operational a bit longer. I did the "reset" thing a few times also and that would only work for a day or so for me.
Old 07-19-2010, 09:56 AM
joeyd61's Avatar
joeyd61 joeyd61 is offline
joeyd61 has a great reputation on FTE.joeyd61 has a great reputation on FTE.joeyd61 has a great reputation on FTE.joeyd61 has a great reputation on FTE.joeyd61 has a great reputation on FTE.
my 03 does the same.....no windows,radio..in a few minutes all is well...i have found that i can open the drivers side door,count to 5 and close it and all is well also....
6.0 won't crank marshall5610 6.0L Power Stroke Diesel 96 11-12-2016 02:17 AM
Radio stays on after key is out. Little General 1999 to 2016 Super Duty 20 01-11-2015 08:18 AM
Sounds like a shorted headlight switch? IDIDieselJohn Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 06-23-2014 08:00 PM
radio on, power door pops up dadto6 Excursion - King of SUVs 2 03-04-2013 03:26 PM
E=150 Van Power Locks Relay? crankbait321 Electrical Systems/Wiring 12 03-20-2007 12:11 AM
Tags
2004, 2005, 2007, 250, ajar, door, f150, f250, ford, olds, opened, opens, power, radio, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
