fuel vapor valve
fuel vapor valve
Hey guys. i'm putting the wiring harness back in my truck and ran into this valve. I ran a search on the part number E4TF- 9C915-AA and came up with fuel vapor solenoid valve or something. What does this do?? It has 2 vacuum lines on it. Does anyone happen to know where the vacuum lines run for this? I pulled the bronco in the shop to see if i could find it on there and it must be under the upper intake or on the other side of the TB b/c i do not see it anywhere. Thanks guys.
OK, so what i'm talking about is called a CANP solenoid. thanks for that correction. I guess i better start looking for where that line comes up from the tank rollover valve. is that Carbon Canister over by the passenger side fender??? Have to ask b/c it's been a good year since i tore this thing apart!!
On edit: where is this purge flor sensor at also????
The carbon canister is located on the passenger side frame rail/inner fender. On an OBD-1 equipped vehicle there is no flow sensor for this circuit. The PCM senses the current flow to the solenoid to determine if the valve is opening when commanded.
I should have made note the drawing was for a '96 T-bird which does have OBD-II. The overall diagram I thought was pretty good otherwise.
It's a very good diagram and i appreciate it. Thats a relief though. I was wondering what that canister was on the passenger side there so i got two of my questions answered in one shot. Thanks man. this is a huge help. Reps sent!!!
edit: for some reason it won't let me send you a rep, but i do appreciate the help a lot.
elkhunter
23
07-28-2023 10:48 PM
05victorylly
24
12-19-2015 06:30 PM
Gary Lewis
26
08-30-2010 03:31 PM
dimora
04-26-2004 07:57 PM
