03 Escape coolant leak - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 07-18-2010, 08:33 AM
spdracer50 spdracer50 is offline
spdracer50 is starting off with a positive reputation.
Doesn't appear to be leaking from rad or any hoses or overflow tank,it leaks right out the bottom,it started as a slow leak,had to add coolant once every 2 weeks. now it's about once a week. As the budget for this repair is $0 right now,was wondering if anybody has ever used Rislone copper block sealer or any similar products with any success.Thanks
Old 07-19-2010, 11:47 AM
martin_csr martin_csr is offline
martin_csr is starting off with a positive reputation.
Have you identified where the leak is? Like, is a hose leaking, or is the thermostat housing leaking?
Old 07-19-2010, 12:17 PM
Quote:
I couldn't spot it anywhere,luckily I have a very trustworthy mechanic who found the leak and it's just a hose. Another bullet dodged.
Old 07-19-2010, 12:33 PM
Did he show you the hose by any chance? And did he mention any other hoses that ought to be replaced. I replace stuff like that as a set, assuming they're originals.
PS: glad you got it fixed. That was an easy one.
Old 07-19-2010, 12:37 PM
The only other one he noticed was a cracked pcv hose. Changing them all sounds like a good idea though, gonna do the ones I can get at myself.
2006 powerstroke coolant leak Jesseprince717 6.0L Power Stroke Diesel 1 10-07-2016 01:10 PM
Occasional overnight coolant leak Ricson 6.0L Power Stroke Diesel 13 02-24-2012 06:53 PM
Front Cover Leak Mr. Sandman 6.0L Power Stroke Diesel 6 01-13-2012 06:13 PM
Coolant leak from back of engine, only when cold dbcrowell 6.0L Power Stroke Diesel 7 09-17-2011 08:16 AM
Coolant Leak Pt.2 SnoPro1234 1999 - 2003 7.3L Power Stroke Diesel 41 02-26-2011 09:37 PM
Tags
03, 2003, 2007, antifreeze, change, coolant, engine, escape, ford, leak, leaking, leaks, mazda, rear, tribute
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
