CDR Test - Ford Truck Enthusiasts Forums
CDR Test
Old 07-18-2010, 02:15 AM
swooshcmk swooshcmk is offline
swooshcmk is starting off with a positive reputation.
CDR Test
Ok I've searched and done the CDR test, which it would seem mine should be good (cover the exit and blow on the intake and the diaphragm moves, or blow on the vent hold and the diaphragm moves). But really, when it's sitting there I can suck and blow on either side and it's just like blowing through a tube - is that right? I'd think there should be some sort of restriction right? Else there's no difference from a straight hose..
Do I have a good diaphragm with a bad valve seat or something?
Old 07-18-2010, 09:17 AM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
The CDR restricts the blowby by closing in and making the passage slightly smaller. Ensure the small hole on the rear is open so it will allow air in and allow the diaphram to work.
Do you know when to service your CDR valve?
All 6.9L and 7.3L diesel engines are equipped with a CDR (Crankcase Depression Regulator) valve. Even the new 7.3L Power Stroke is also equipped with the same valve. The CDR valve is one of the leading causes of head gasket failure in these engines. The CDR valve is responsible for controlling the pressure/vacuum in the engine crankcase, and seperating the oil mist from the air and returning the oil to the crankcase. The CDR valve should be serviced every second oil change or when signs listed below are seen.
When the CDR valve is not properly serviced, engine oil enters the air intake and is drawn into the engine. The diesel engine will burn this oil as fuel, however, it is heavier and thicker than diesel fuel and, having greater BTU output, causes excessive heat in the cylinder. Due to the intake manifold design, most of the oil will migrate to #7 and #8 cylinders; the last two cylinders in the rear by the firewall. The increased temperature here will cause the cylinder head to lift off the gasket and allow water or oil to leak out the back of the cylinder head where it meets the block.
To check your CDR valve, remove the air cleaner hold down bolt and inspect it. If the bolt is covered with engine oil mist, it's time to service your CDR valve! Ford calls this item a "Adapter assembly for Crankcase Ventilation" Part number E3TZ-6A665-A or IH part #1805319C1
To service the CDR wash with a solvent, allow to dry, do not use compressed air to dry. There is a small hole in the CDR back cover, ensure it is clean and open. If black chunks of rubber are visible in the intake, on the screen then the rubber membrane has disintegrated, replace the CDR.
CDR valve parts
IH part #1805319C1
Old 07-18-2010, 02:13 PM
yeah I tested it and cleaned it but it still seems to be letting oil past so that's why I asked.
School me on CDR chillman88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 11-05-2016 03:41 PM
Oil in intake?? rterril02 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 10-03-2016 03:44 PM
A/C doesn't always blow through vents big79bronco Ranger & B-Series 5 11-22-2014 09:44 AM
Just Blew My CDR Diaphragm mechelement Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 06-04-2014 11:39 PM
94 turbo cdr? beechkingd Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 06-01-2014 07:15 AM
Tags
1805319c1, 6a665, 73, 73l, adapter, assembly, cdr, crankcase, depression, e3tz6a665a, ford, ih, part, regulator, test, valve, ventilation
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
