Blue Smoke at Idle ? - Ford Truck Enthusiasts Forums
Old 07-17-2010, 10:08 PM
royzell royzell is offline
royzell is starting off with a positive reputation.
Question Blue Smoke at Idle ?
Hey all,
I'm looking (long distance) at a 94 IDI turbo. He said he has replaced injectors, lines and IP. It smokes at idle but apparently goes away at speed / higher RPM.
I have seen a video of it idling, and the smoke is blue.
Video link
YouTube - MVI_0061.AVI
He thinks it is mis-timing of the IP. I thought that would make black smoke.
Thoughts / Ideas ?
Old 07-17-2010, 10:46 PM
charleswood6969 charleswood6969 is offline
charleswood6969 is starting off with a positive reputation.
If it has new injectors, pump and lines, I would check the compression. Low compression equals incomplete fuel combustion because of low cylinder temperature. I would also check the CDR valve because it could be oil being sucked in and burned thru it. What about abnormal oil usage?
Old 07-17-2010, 10:54 PM
Oh, and if it has a turbo, I would suspect it has possibly blown a seal. Check inside of the intake piping from the turbo to the engine for oil.
Old 07-17-2010, 11:07 PM
Festus Hagen's Avatar
Festus Hagen Festus Hagen is offline
Methanoholic
Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.Festus Hagen has a great reputation on FTE.
Blue smoke is typically motor oil, Could be Turbo seals, Need to find out if there is any motor oil in the intake system anywhere ...
A little blue smoke wouldn't scare me away, a little blue smoke is likely a little problem, heavy blue smoke could be one to run from!
-Enjoy
fh : )_~
Old 07-18-2010, 01:30 AM
David85's Avatar
David85 David85 is offline
David85 has a good reputation on FTE.David85 has a good reputation on FTE.
Seems to idle pretty good.......hmm.
Timing being off can produce blue smoke but I kinda doubt it could make that much to be so visible on a camera like that. Unless he removed the drive gear and messed up the timing that far...
I would definately have a look at the CDR valve and see what sort of blow by is to be found. Too bad you can't truly observe oil consumption on a test drive.
Turbo seals could certainly do that too.
From what I've seen burning oil in small amounts can burn clean once you are running under load with high enough EGTs. Timing being off at least with my engine still produces colored smoke even under load.
Old 03-08-2012, 03:24 AM
maverick1701's Avatar
maverick1701 maverick1701 is offline
maverick1701 has a good reputation on FTE.maverick1701 has a good reputation on FTE.
hmmm my truck has started doing that same thing at idle.
Time to check ye ole CDR and everything yay.
Old 03-08-2012, 04:41 PM
eatont9999's Avatar
eatont9999 eatont9999 is offline
eatont9999 is starting off with a positive reputation.
Nice looking truck.
I agree with the guys above. CDR, turbo seals, or timing could cause that. So could a bad injector or two. Unless he put a timing meter on it, after the IP install, it probably needs the timing set anyway.
Old 03-08-2012, 06:07 PM
Aune163rd's Avatar
Aune163rd Aune163rd is offline
Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.Aune163rd has a very good reputation on FTE.
Old thread, i doubt the OP bought the truck guys...
Old 03-08-2012, 07:02 PM
Quote:
yea, we know. I bumped the thread because my truck is acting in a similar fashion. We are talking about it now.
Rebuilt engine issues -- what did I do wrong? Macrobb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 30 11-28-2016 04:47 PM
Injection Pump calibration question LordKamakazi Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 05-05-2016 11:51 PM
'85 6.9 Injection Pump trouble MrVerilog New Member Introductions 6 10-29-2014 06:05 AM
Rough idle cold with blue/white smoke jr_vw2 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 07-09-2012 04:45 PM
valve job? 91dirtydiesel Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 05-28-2012 10:25 PM
Tags
60, 69, 73, 73l, 94, blue, diesel, ford, heavy, idi, idle, smoke, smokes, turbo, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
