WTB-Brake Pressure Sensor 2005 F-350 - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Old 07-17-2010, 07:06 PM
stackedstroker1 stackedstroker1 is offline
stackedstroker1 is starting off with a positive reputation.
Needing a brake pressure sensor for a 2005 F-350 Lariat, this is the sensor on the bottom of the master cylinder closest to the front of the truck. Also needing a brake position sensor for the same vehicle, this is the sensor on the back of the brake pedal. if anyone has these sensors or can point me in the right direction to someone that might I would greatly appriciate it. Thanks
Old 07-18-2010, 03:11 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
I would just buy a new sensor, its not a very expensive one.
Old 07-18-2010, 09:24 AM
Quote:
Both are only available from Ford from what I have researched...position switch is only 20 bucks, but they want 112 for the pressure switch..figured I could get a much better deal on the pressure switch at least.
Old 07-18-2010, 12:23 PM
I am needing one too, I just have the harness shorted with a piece of wire to satisfy the computer so the ABS light is out and cruise control will work. I thought I saw it listed at RockAuto a while back when I was looking.
Old 07-18-2010, 05:03 PM
If you have pics of your ingenuity and feel like sharing send em my way, ( im not so good with electrical stuff) I'm needing a temporary fix myself..ill pm my email to you if you want
Old 07-18-2010, 05:21 PM
Just unplug the harness from the sensor, bend a paperclip or piece of wire to insert in the harness side of the plug and short the two contacts, and tape over it with electrical tape to keep it in place.
Oil Pressure Sensor jdq1986 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 06-22-2016 10:42 PM
Aftermarket exhaust and EBP sensor T Webber 6.0L Power Stroke Diesel 2 08-10-2014 10:40 PM
ICP Voltage Problems carrcreekcaller 1999 - 2003 7.3L Power Stroke Diesel 5 01-16-2012 06:13 PM
i need some help ampslw 2004 - 2008 F150 4 01-29-2011 08:17 AM
F350 In Cab Brake Controller WK57ABF 1999 to 2016 Super Duty 2 04-10-2009 06:04 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2004, 2005, 2008, 2010, 250, brake, diesel, f150, f250, f350, ford, pressure, sensor, switch, transducer, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
