You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have a 95 f350 powerstroke. Im having a problem with no comunication with my scan tool. Ive tried both a otc.genisis & a snapon and no go with either truck starts and runs but cranks a little longer than I think it should, glow plugs are new as well as all gaskets harnesses and relay and they are working correctly. Ived traced the wires from the aldl connector to the ecm. & have continuity & power & ground also to the connector Ive checked all the fuses and am just about at my wits end if anybody has any sugestions Id apreciate it thank Irv
Likely the IPR needs o rings. Unless you have a CEL or the engine is running erratically I wouldn't think you would absolutly need to scan it. The OBDII connector is in the cab?
__________________
Pete in San Ramon
2005 F250 6.0 Lariat 4x4 CC Short bed (stock)
1997 F250 7.3 XLT 4X4 Reg. cab 1.0 housing Banks wheel AC injectors T500 Farmers Diesel pushrods Diamond Eye 4" exhaust DP F6 chip Electric fuel S@B intake
Scanner may not work on the 95 ...
__________________
Rick.......
"Most stuff's just stuck & needs hittin with a hammer".... Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
'Life may not be the party we hoped for... but while we are here we might as well dance!'
__________________
Mike. 97 F250 totaled 11/19/12 B.E.S.T. mapLouisiana FTE Member Map
2012 Ram CC 1500 5.7 Hemi
Diablo sport trinity hemi fever tune, 87mm throttle body, BBK headers, HF cat, 14" magnaflow, AFE intake, 180* T-stat. All waiting for time to be put on.
When married you have two simple choices. You can be "Happy" or you can be "Rite" you can't have both
Are you using the OBD connector under the hood or under the dash? You may have both....my 96 does.
If your 95 hasn't been flashed up to OBD2 the one under the dash won't work. The OBD1 connector under the hood won't give you much info if it works at all. Most scanners aren't capable of scanning our diesels...are they compatible?
