spark plug gap for 1985 f250 460 engine - Ford Truck Enthusiasts Forums
Old 07-17-2010, 02:16 PM
r2000f150 r2000f150 is offline
r2000f150 is starting off with a positive reputation.
hi guys thanks for your help just got truck and don't have a manual yet can you tell me spark plug gap for a 460 engine thanks again
Old 07-17-2010, 02:26 PM
TheKirbyMan's Avatar
TheKirbyMan TheKirbyMan is offline
TheKirbyMan has a good reputation on FTE.TheKirbyMan has a good reputation on FTE.
Under the hood to the left of the hood release lever, there should be a square/rectangular sticker that lists emissions info. It should list your plug gap there. For example, for my 81's 302, it says that a gap size from .042 to .046 is the proper gap size.
I personally would recommend using Motorcraft plugs, they're cheap but they work very well and I've never had a problem with them.
Old 07-17-2010, 02:28 PM
yes thanks
Old 07-17-2010, 02:29 PM
Rockstone's Avatar
Rockstone Rockstone is offline
Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.Rockstone has a great reputation on FTE.
.042 - .046
Old 09-14-2012, 02:55 PM
norts1138 norts1138 is offline
norts1138 is starting off with a positive reputation.
★****★****Corrects park plug gap 1974 f250 360. V8. 2bbl★*******★
I'mgetting ready to changing myspark plugs and have been getting differnet info on the gap size.
The auto parts store said. 044 but the emissions sticker on my valve cover says.032-.036
For all I know thesticker on the valve cover could be from another truck at some point
The sticker also says it was manufactured in November 1973 but the truck is a1974.
Now I'm confused as I read that the gap size changed in 73/74 for the 360 .
Any help would be great I'm not a car expert .
Old 09-14-2012, 03:48 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
I would go by the valve cover spec. You do know the 1974 vehicles were usually available for sale in the fall of 1973? That's the way it always was, except a few oddballs like the 64 1/2 mustangs. I think they were introduced in the spring of the year?
Old 09-14-2012, 03:53 PM
I did some more research and it says the 360 was changed from points to electric ignition in1974.
I'll just pop open the distributor cap and look and see what which I have.
Chances are that someone could have also changed it from points to electric at some pout too.
Thanks for the reply
Old 09-14-2012, 04:11 PM
Franklin2's Avatar
If you have electronic, you will have a box mounted on the fender with wires going from it to the dist.
Plug gaps are just like tires, they are a compromise between performance and plug life, just like tires are a compromise between traction(being softer) versus tread life(harder rubber).
The wider gap will raise the voltage available at the plug, producing a larger spark. But this means the ignition system has to be in top shape, and the plugs can't wear much or the gap will get too big and it will miss-fire. Too small a gap, and your spark will be small, but the plugs and the rest of the ignition will have a long easy life, even though your engine will not perform as well. So the gap is a compromise between the life of the plug and the performance of the engine. The electronic ignition has more oomph behind it, so it can stand a little bit wider gap than the old points style ignition.
Old 09-14-2012, 06:11 PM
I have points.looking forward to to a time up this weekend.Thanks for the help
Spark Plug Gap for 361 with 4v ?? 1975-F6004x4Dump Large Truck 2 02-12-2014 07:00 PM
361 Spark Plug gap ?? 1975-F6004x4Dump 1973 - 1979 F-100 & Larger F-Series Trucks 1 02-12-2014 01:41 PM
Spark plug gap xd40c 1999 to 2016 Super Duty 3 10-14-2013 02:23 PM
Spark Plug Gap copperjohnc 1987 - 1996 F150 & Larger F-Series Trucks 11 09-29-2011 12:02 AM
spark plug gap, 93 460 bigcrunch 1987 - 1996 F150 & Larger F-Series Trucks 0 12-05-2009 06:05 PM
Tags
1985, 1994, 302, 400, 460, 78, engine, f250, ford, gap, gapping, motor, pickup, plug, plugs, proper, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
