Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 07-17-2010, 11:45 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
Magnesol in fuel bowl
I made another trip accross the state with 33 gallons of bio in the tank. got to the steep hill crossing the Missouri River, and it throws a code going up the hill. ran a little rough and lost power / down shifted. I get to Sioux Falls, and have them check the code, 1211 (fuel/air ratio) is running fine so have them reset it. Get to the river going back, and the same thing happens. Pull over at a truck stop and check the fuel filter. When I go to pull it out, the fuel bowl is full of Magnesol up to the bottom of the filter. Clean it out in almost 100 degree heat (not fun) and put on my spare filter. No problems since, and took the boat up in the hills yesterday.
I filter through 7 inch diameter sock filters 25/10/1 micron. most Magnesol is caught by the first two. I then pump through a 10 micron spin on filter to catch anything that might get through. ( Should I find a 2 micron instead? )
Anyway, I think that I will check the bowl in another 1000 miles and see if there is Magnesol in there again.
What do you guys think? The Magnesol could have built up before I added the spin on filter but???
thanks,
Trent
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #2 (permalink)
Old 07-26-2010, 07:03 PM
Knotwild Knotwild is offline
Garage is empty, add now
Knotwild is starting off with a positive reputation.
I am sorry you had that problem. I have run about 40,000 miles on magnesol washed fuel and never found it in my fuel bowl and it sounds like you are filtering well. How do you agitate your magnesol? You should use a mechanical mixer, diaphragm pump, or other agitation that does not grind the magnesol up like a centrifugal pump will.
I agitate with a paint stirrer adapted to an electric motor, let the fuel settle for at least two days after applying magnesol, gravity filter, pressure through a 1 micron nominal bag filter and use a 1 micron nominal canister filter on my transfer tank pump.
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP exhaust, 6637 intake mod, Dieselsite 203 thermostat, Airdog II electric fuel system with fuel bowl delete.
  #3 (permalink)
Old 07-26-2010, 09:39 PM
Rushmore X's Avatar
2003 Ford Excursion
Sounds alot like what I am doing. Maybe tomorrow I will try and attached some pics of the wash setup. Will pull the fuel filter again after my next trip and see if there is any build up again.
__________________
  #4 (permalink)
Old 07-27-2010, 07:47 AM
I think I would start by taking a quart sample of the fuel that goes into the truck and let it settle for a few days to a week. If you find magnesol settling, then something is out of whack in your filtering. The best thing I ever did was buy a bag filter housing from Fryer to Fuel and the fuel goes through it twice with a 1 micron nominal filter. The magnesol is supposed to be manufactured in a way that sizes it to a size that filters will catch (I am not sure of the micron size for this).
JM Ellsworth has 1 and 2 micron canister filters that are rated for biodiesel. Keep in mind that a red blood cell is 6-8 microns in diameter.
I guess I really rely on settling to get most of my magnesol out. I also demeth the fuel, let it settle for a few days to a week, then decant, clean the tank, and refill for the magnesol treatment. I am able to use less magnesol to clean it up.
__________________
  #5 (permalink)
Old 07-27-2010, 10:43 AM
Rushmore X's Avatar
2003 Ford Excursion
I might not be letting it settle out long enough, usually stir it in for a half hour, then let settle overnight. I then pump it out, trying to be carefull not to let the pickup get into the Magnesol.
__________________
  #6 (permalink)
Old 07-27-2010, 11:38 AM
Rushmore X's Avatar
2003 Ford Excursion
Dry wash pictures
Name:  Dry wash system 001.jpg
Name:  Dry wash system 003.jpg
__________________
  #7 (permalink)
Old 07-27-2010, 08:10 PM
Here is something I got off of Fryerpower's website:
The average size of Magnesol R60 particles is 60 Microns. 10% of the particles are <20 micron in size.
If you are in biodiesel for the long run, I would order a bag filter from Fryer to Fuel and run 1 micron nominal bag filters. It is worth it in the long run as canister filters are so expensive.
If it were me, I would decant by gravity, not by pump, and settle as long as possible.
Good luck!
__________________
Tags
bio, biodiesel, buy, collects, filter, filtering, fuel, magnasol, magnesol, pump, removing, rinconga, size, sock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
