Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 07-17-2010, 11:08 AM
douglpr42 douglpr42 is offline
Garage is empty, add now
douglpr42 is starting off with a positive reputation.
what manual 4speeds were used in 87
my son has a 1987 f250 4x4 with a man. 4 speed and we need to know what tranny. it is as he needs to find some parts for it. any help in identifiing it would be great . thanks ron douglas it is a canadian truck.
  #2 (permalink)
Old 07-17-2010, 12:21 PM
gijoe4500 gijoe4500 is offline
gijoe4500 is starting off with a positive reputation.
4 speed, non-O/D should be the np435.
  #3 (permalink)
Old 07-17-2010, 12:35 PM
danger-ranger93's Avatar
danger-ranger93 danger-ranger93 is offline
danger-ranger93 is starting off with a positive reputation.
or it could be the borg warner T18
__________________
Michael, but you can call me Michael, or danger ranger what ever you preffer
'87 f150 4x2 reg cab short box, 302, M5OD-R2, custom cab sold.
'96 f150 4x2 extended cab, 302, M5OD-R2. XL FOR SALE
'78 F250 4x4 reg cab long box. Project
'00 F150 4x4 supercab, 5.4, auto XLT, DD
  #4 (permalink)
Old 07-17-2010, 12:53 PM
Rulebreaker's Avatar
Rulebreaker Rulebreaker is offline
1989 Ford E-Series Van
My Garage
Rulebreaker is starting off with a positive reputation.
If it's got an aluminum top cover it's the 435.
__________________
Check out my webshots page.
75 Ford Bronco 5.8L EFI,NP435,D20 on 35" MTR's
96 E350 24 passenger bus 7.5L
93 Ford Broncostar 4.0L NP435 BW1356 (Avatar)
95 F250 4x4 351, E4OD, 1356
98 Ranger 3.0L
  #5 (permalink)
Old 07-17-2010, 04:09 PM
phoneman91's Avatar
phoneman91 phoneman91 is offline
phoneman91 is gaining momentum as a positive member of FTE.phoneman91 is gaining momentum as a positive member of FTE.
To be absolutely sure-check the VIN sticker on the driver's side B pillar. It is visible when the driver's door is open. There will be a one letter code under the category of "Trans".
This is absolute-only if the transmission is still the same factory tranmission and hasnt been changed.
__________________
92 F150 XLT 4x4, SWB, 5.0 V8, 5sp ,118k on M1/Amsoil synthetic oil. Power everything. Trailering/Handling option(stabilizer bars front /rear and quad shocks).Factory skid plates,manual hubs, manual Tcase, Super Cooling. 4.09/4.10LS axles. 31'' BFG KO tires. 20.3 MPG @ 60 MPH.4350 lbs with full tank of gas!! 2150RPM@60MPH All options but 4!
  #6 (permalink)
Old 07-18-2010, 07:00 AM
thanks for the help .now will go see what it looks like. thanks again p.r.douglas
  #7 (permalink)
Old 07-18-2010, 07:32 AM
tjc transport's Avatar
tjc transport tjc transport is offline
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
depends on what engine it has also.
could be a NP 435, a T18 or a T19
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
  #8 (permalink)
Old 07-18-2010, 12:26 PM
Hitokori's Avatar
Hitokori Hitokori is offline
Hitokori is gaining momentum as a positive member of FTE.
NP435
will have an aluminum top cover
Click the image to open in full size.
T18-T19
T18 had an un-synchronized 1st
meaning u can really downshift from 2nd into first without a little grinding noise
T19 all forward gears were synchronized
meaning u can easily down shift into first
__________________
Matt
Whats the diff between your wife and your job? After 10 years your job still sucks
  #9 (permalink)
Old 07-18-2010, 03:35 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
1980 Ford F-350
My Garage
Diesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to beholdDiesel_Brad is a splendid one to behold
The NP435 had an aluminum top cover and a PTO cover on the passenger side
The T18 had a cast iron top cover with a PTO cover on the passenger side
The T19 had a cast top cover with a PTO cover on both sides.
There was at least 2 different OD trans as well. One, reverse was up and to the left, the other has the typical "H" pattern with reverse down and to the right
__________________
96 F350 CCLB 460 5pd 4x4 /97 F250 CCSB Dually 7.3 5 spd 4x4
94F150 RCSB Lightning/86 F250 RCLB 6.9 4spd 4x4
80 F350 RCLB 429 C6 4x4/
04 Ranger SCSB
96 Bronco 347 5speed
  #10 (permalink)
Old 07-18-2010, 04:45 PM
phoneman91's Avatar
I believe that only T18s were the only four speed factory installed with gas engines 87 thur 93.
__________________
  #11 (permalink)
Old 07-18-2010, 05:01 PM
i know it was T-18 for gas engines and T-19 for diesels, but i believe you could still get the NP 435 in 87as an option.
__________________
Tom
Tags
1989, 1st, 4x4, 87, diesel, downshift, f0rd, f150, ford, kind, manual, materials, speed, tranny, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
