Power Door Lock repair - Ford Truck Enthusiasts Forums
Old 07-17-2010, 09:29 AM
lauraj lauraj is offline
lauraj is starting off with a positive reputation.
Hi,
I have a 1997 F350 Crew Cab, 7.5L engine. My rear power door locks are not working. I recently had to replace the door handle on the driver side and am wondering if I may have messed something up? I was by myself so had to let the door panel hang for a few minutes while I changed the door handle. They did work for several days, but then quit. I was having problems with the left passenger door power lock being sticky prior to this repair. Any ideas?
Also, where can I obtain a good, comprehensive repair manual (bumper to bumper) for my truck? They have them for every year except 1997???
I have over 280,000 mile and want to keep my truck, but it needs some basic repairs, cosmetic and mechanical. I can do some minor jobs myself if I have good instructions.
Laura
Old 07-17-2010, 04:57 PM
Hunt4Fun Hunt4Fun is offline
Hunt4Fun is starting off with a positive reputation.
The door actuators are notorious for going out, but usually not how you described it. When they get worn the will lock, but fail to always unlock. Since the problem started so close to your replacement of the door handle, I would return to that door and check all of the wires going down to the actuator. It is easiest to do with a voltmeter. Find the wires going to the actuator, put a straight pin in each, and use a couple of alligator clips to attach the voltmeter leads to the straight pins. That way you can do it by yourself. Hit the lock button and see if you get +12Volts or -12Volts(if the wires are switched. If you don't the problem could be the wiring coming to the actuator. To test the actuator, if you have a spare battery available, you can put 12Volts directly on the leads to it. If the actuator is good it will either lock or unlock.
Switch the wires (positive and negative) and the lock should go the other way.
Hope this helps. A voltmeter for what you need is very inexpensive if you do not have one and you'll find other uses for it as well.
Post back if this doesn't diagnose your problem.
Hunt4Fun
Old 07-17-2010, 09:28 PM
Thanks! Sounds like a good place to start and hubby has a voltmeter....
Laura
Old 07-18-2010, 04:31 PM
tacoterry tacoterry is offline
tacoterry is starting off with a positive reputation.
door lock power?
I have a problem, both by drivers side and passenger side switch will unlock the driver side door lock which has 12 volts going to it when I press th button. But none of the other locks have any voltage going to them. I dont have a wiring diagram to look and see where all these wires go. Does anyone know why none of my other actuators dont get 12 volts?
thanks
Old 07-18-2010, 04:36 PM
93MARKIII's Avatar
93MARKIII 93MARKIII is offline
93MARKIII is starting off with a positive reputation.
make model year ??......it makes a difference
Old 07-18-2010, 05:19 PM
2001 ford windstar
Adding Rear Seats? Laura Tabor Thompson 2004 - 2008 F150 1 01-24-2015 05:03 AM
Crazy Door Locks lauraj 6.0L Power Stroke Diesel 2 11-13-2014 09:42 AM
2007 F350 Dually 6.0L Steering prob. lauraj Brakes, Steering, Suspension, Tires, & Wheels 1 01-06-2014 02:02 AM
HELP! Power Door Locks (door will not lock) greenmachinejohn 1999 to 2016 Super Duty 0 12-16-2013 06:31 PM
Need reliable Diesel Repair shop near Conroe lauraj Texas Chapter 2 05-01-2013 10:05 AM
Tags
1997, 99, car, door, electric, f150, f250, ford, lock, locks, power, pu, repair, replace, sticky, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
