When it rains... New issue with truck, some sort of differential/tranny/hub problem
ehgeeray, that's what I read on the forums, thanks alot. It seems to be working fine. What are other's opinions on Mobil 1 75w140?
RSUPER,
The EGR delete is working out great. No issues whatsoever with it. I cannot intelligently speak to any performance gains because I did not own the truck very long before I did the delete. But not routing exhaust into the intake and not purposefully heating my coolant even more just seems like an all around better way to travel.
I did not get any codes, I did not have any special tunes. I merely reinstalled the EGR valve, plugged it back in, and started the car.
RSUPER,
For what it's worth, because you have an '05 like I do, you might get lucky not having to get a special tune. From what I have read, the consensus is that some '05s you can just plug back in the EGR valve, and some you'll have to get a tune. Hopefully yours will be like mine.
tony2toes
04-08-2014 10:03 PM
housedad
09-18-2011 11:52 PM
ckstrawser
25
12-22-2009 09:57 PM
